C1 - problems with clone 2x4 setup
Old Oct 17, 2007 | 10:14 PM
black1961's Avatar
black1961
Default C1 - problems with clone 2x4 setup
I purchased a set of WCFB clones over two years ago from a vendor I met at Bloomington. The car is about ready for the road, it starts and runs good, but I ran into a clearance problem when fitting the hood. Can these WCFB carbs be reworked to solve my clearance problems? Who would you recommend? Please don't suggest that I send them back to the vendor, I wouldn't give him the satisfaction.
Thanks in advance,
Paul
Old Oct 17, 2007 | 10:25 PM
Coves4me's Avatar
Coves4me
Exactly, what's the problem? Hood hits the top of the air cleaner? Hood hits the screw-in air cleaner hold downs? Are you using the correct intake manifold? Is the front fiberglass front end of your car drooping?
Old Oct 17, 2007 | 10:28 PM
Frankie the Fink's Avatar
Frankie the Fink
Army
Unless you have a high-rise manifold or some strange variant of WCFBs they should fit by default - they were stock equipment for the hi-horsepower, non-fuely cars in '61. I run a pair myself with no clearance problems. http://members.capital.net/com/studiog/CarterWCFB/
Has somebody put a big carb spacer underneath the WCFB's to reduce heat exchange ? Pictures would help.
Old Oct 17, 2007 | 10:29 PM
L78racer's Avatar
L78racer
on real 2x4 carbs, the carb bases are about 1/4" thinner than a regular WCFB base. that is possibly what the problem is.
however, i have seen clones on many other vettes and saw no problem.
make sure your engine mounting and trans crossmember are correct and installed correctly.
how much room are you lacking?
in the pic you can see the front carb has the wrong base, and the rear carb has the correct base. Notice the height difference between the two carbs.
Plasticman's Avatar
Plasticman
Thanks in advance,
Paul
They sure should work since dual WCFBs were an option in 61. I have dual AFBs on my 62, with an Offenhauser manifold, with 5/16" insulator spacer gaskets, but am not running the stock air cleaner either.
What air cleaner were you using, and are you sure the engine is located at the correct hgt.? Especially at the rear trans mount? What intake manifold are you using?
And what is a WCFB clone? Are you saying they are WCFBs, but just not the correct number?
Pics would help.
Plasticman
Old Oct 17, 2007 | 11:28 PM
black1961's Avatar
black1961
The hood hits the top of the air cleaner. The intake manifold is correct. The air cleaner is correct. The fiberglass front end has been supported/shimmed under the radiator core support. I suspect the WCFB cast iron bases are too thick.
Old Oct 17, 2007 | 11:35 PM
black1961's Avatar
black1961
The carbs do not have a large spacer underneath. Stock intake manifold & air cleaner. Thanks for the link to the CarterWCFB site.
Old Oct 17, 2007 | 11:40 PM
black1961's Avatar
black1961
You've raised a good point with the trans crossmember. I'll check that out. I know the engine mounts are stock. Can the carb bases be interchanged? I suspect that my bases are incorrect.
Old Oct 17, 2007 | 11:50 PM
black1961's Avatar
black1961
[QUOTE=Plasticman;1562356031]They sure should work since dual WCFBs were an option in 61. I have dual AFBs on my 62, with an Offenhauser manifold, with 5/16" insulator spacer gaskets, but am not running the stock air cleaner either.
Pics would help.
Plasticman[/QUOT
Per the previous reply, I'll check the rear trans mount. Your right, the WCFBs are not the correct number, they were supposed to have been
reworked for the Corvette application (the vendors call them clones). I know they won't pass judging, but they appear similar (with an aircleaner) and sell for approx. $1300 less than the correct carbs. I know others have used clone carbs without problems.
Old Oct 18, 2007 | 12:25 AM
71zman's Avatar
71zman
A trick I used to figure out where the air cleaner is hitting is get some kids playdooh, make a couple of ***** and place around your air cleaner, close the hood as far as you can then reopen, where is the playdooh the thinnest in the front or back of the air cleaner - if in the back - maybe trans mount or carb base or combination of both, if in the front - something else??
Old Oct 18, 2007 | 02:41 AM
bowtie racing's Avatar
bowtie racing
This is intresting!!
Can somebody tell me wich carbs should i look for to get "correct look" with stock manifold but slightly modified engine ? I am trying to say is there a difference in adjustability with AFBs or WCFB ??
Old Oct 18, 2007 | 07:39 AM
wmf62's Avatar
wmf62
St. Jude Donor '07
just a wild thought... but could you swap carb bases from the front carb to the rear one? because the engine/driveline slopes downward towards the rear and the hood slopes upwards towards the rear, you might be able to get the necessary clearance because the taller carb might have more clearance that way.
you could try this to get an idea if it would solve the clearance problem by simply swapping whole carb positions (front to back, back to front)
Bill
Old Oct 18, 2007 | 09:28 AM
L78racer's Avatar
L78racer
It's not an easy answer.
I've seen many 1x4 carbs used in cloning the 2x4 setup. I've also seen many AFB's with adapters on original manifolds. Some 1x4 carbs have slightly larger venturis. Low choke WCFB's(3059's) are also being used as clones. They have slightly bigger throttle bores etc.
I have used both real and clone carbs on my '57 at the Pure Stock Drags. The clones were 2505 '57 1x4 carbs. After getting the jetting correct in both applications using an A/F meter, I saw no difference in performance, driveability or ET's. I ran both sets on the same day at the same track. No problems with hood clearance on the clones either. If you're just looking for the 2x4 eye candy, Edelbrock has a 2x4 setup that looks and runs good.
Old Oct 18, 2007 | 10:45 AM
dgsmith's Avatar
dgsmith
I have used two AFB's with the stock prog. linkage, required slightly lengthened bell crank on the primary carb. What I did was use two very early AFB's (square bore, about 400 cfm) that had the same size horn as the WCFB . That way I can use the stock dual air cleaners that were on a '56. I also use an Edelbrock C-26, which mounts the carbs closer together than the stock 2X4 and so increases clearance a bit. However, the Edel. is higher than the stock and with 1/2" spacer the wing nut of the front cleaner hit the X-brace under the hood. A little with a hole saw solved the problem.
Old Oct 18, 2007 | 08:07 PM
Pierre's Avatar
Pierre
I have a set of originals and a set of clones for my '56. Ther is only an 1/8" difference in height between them.
Pierre
Old Oct 18, 2007 | 08:14 PM
56Heap's Avatar
56Heap
There is a difference in the thickness of the base plates between single and 2X4 set-ups. I've seen the thicker bases machined down before. Take it off the intake side if you have too.
To C1 - problems with clone 2x4 setup
