BACKFIRE
Old Nov 15, 2001 | 04:27 PM
CHRISP's Avatar
CHRISP
Default BACKFIRE
Hopped in the vette today and now have a "small" backfire out of the passenger side exhaust. Fairly new to the vette world and was hoping for a little help on where to get started. It's a 62 327 fullie. If it matters, there was a pertronix installed a couple of months ago but no previous problems, new AC45 plugs and wires earlier in the spring. Any input would be appreciated. Could'nt really find any troubleshooting help in the ST-12 or Chiltons.
[Modified by CHRISP, 2:29 PM 11/15/2001]
Old Nov 15, 2001 | 04:56 PM
67HEAVEN's Avatar
67HEAVEN
Default Re: BACKFIRE (CHRISP)
I'd start here:
- check intake manifold gasket for leaks
- spark plugs - look for wear, wetness, cracks, improper gap, burned electrodes, and heavy deposits.
- ignition coil connections
- ignition system for moisture, dust, cracks, burns, etc. Spray plug wires with fine water mist to check for shorts.
- ignition system for faulty grounds
Someone else will have others.
Old Nov 15, 2001 | 05:12 PM
stngry63's Avatar
stngry63
Default Re: BACKFIRE (67HEAVEN)
An aerosol can of starting fluid(ether) is good for finding intake/vacuum leaks. Just spray it in the suspected area and the engine will speed up if there is a leak; like at the base of the carb. Be careful; too much can blow a head gasket.
Old Nov 15, 2001 | 10:01 PM
Vetterodder's Avatar
Vetterodder
Active Streak: 90 Days
Exhaust backfires are usually a result of unburnt fuel being ignited after leaving the combustion chamber (either by a subsequent firing of the same cylinder or by the still burning gasses of an adjacent cylinder). In some cases one cylinder is getting more fuel than it's plug can fire but more often it's the result of an ignitiion miss that doesn't fire the plug. Any of those things already suggested could cause this. Usually, a plug reading will identify the offending cylinder (the one that's not firing will be darker). Another possibility is a problem in the exhaust sytem. A leak at or near the manifold will let air in to ignite unburned fuel and also let you hear the result.
Old Nov 15, 2001 | 10:17 PM
CHRISP's Avatar
CHRISP
Default Re: BACKFIRE (Vetterodder)
Thanks to all for getting back with me. Just found the problem, bad plug wire. #6 :seeya
Old Nov 15, 2001 | 10:26 PM
67HEAVEN's Avatar
67HEAVEN
Ahhhhh....the old #6 problem :lol: :lol:
To BACKFIRE
