engine idetification
Old Nov 15, 2007 | 01:11 PM
mwm1959's Avatar
mwm1959
Default engine idetification
I have ordered books but they haven't arrived yet.
Is there any place online that will tell you more than engine numbers?
I am wanting numbers for trans., rear end, radiator, intake, etc.
Old Nov 15, 2007 | 02:28 PM
Donald #31176's Avatar
Donald #31176
Cheapest booklet for Vette P/N is NCRS Corvette Spec Guide 1953-1967.
Old Nov 15, 2007 | 02:47 PM
TopLess62's Avatar
TopLess62
This site may help. Its a list of what they have but there is some refference material there too.
http://tracyvette.com/blockschevyv8.html
Old Nov 15, 2007 | 04:56 PM
knight37128's Avatar
knight37128
The block will be 3737739 for early or 3756519 for late.
Staggered valve covers will have 3755550 heads or 3767465 with out staggered.
Intake will be cast iron for the single carb 3746829.
3739653 for the dual carb intake.
Lots and lots more numbers. It would be easier if you would post your numbers.
There are 8 engine codes and 12 rearend codes. I'm not typing all that out.
Old Nov 15, 2007 | 05:14 PM
Lakelander's Avatar
Lakelander
Veteran: Marine Corps
This should help, pick the year from the drop down on top & then click on "Identification" on the left
http://www.corvetteactioncenter.com/...1966/66id.html
Here's another link for Muncie trans:
http://www.gearzone.net/muncie2.htm
Old Nov 15, 2007 | 05:55 PM
mwm1959's Avatar
mwm1959
I've been researching all day with what I have. Seems my tranny is not correct.
Engine pad stamp giving me trouble. Looks Like TI209E can't find info on this #
Casting is ok. 3756519
Trans. is Muncie 68 to 70. 3925660 stamped. Hanging TAG SAYS 1915079
Intake is 3844457 which is 64??? not correct.
Rear End says 3789812 gm P posi i believe corrct for 59.(nice option)
Carb is Carter WCFB...ok I think.
Puzzled on Distributor. #1110891
When purchased Iwas told 230hp but distributor says for 245 or 270hp
By the way...245 or 270 hp both say 2x4 barrel. what determines one hp from the other.
Sorry, I know I've thrown alot in this post.
Old Nov 15, 2007 | 06:37 PM
mwm1959's Avatar
mwm1959
I would like to think that when the intake got changed that they went from 2x4 to single as the distributor shows. BUT,,, maybe the engine is right and the distributor is not. I hope the numbers I gave for the engine will tell you and you can let me know.
Again they are TI209E.
Old Nov 15, 2007 | 06:46 PM
Donald #31176
The casting #is correct but the block was cast at the Tonawonda foundry . All small block engines originally installed in Corvettes except some late 65s were cast at the Saginaw foundry so your engine was never originally in a Corvette. T1209E means that the engine was assembled Dec 9 in the year the block was cast at the Tonawonda plant.I dont know the E code .
Old Nov 15, 2007 | 10:27 PM
mwm1959's Avatar
mwm1959
I pulled the valve cover to find # 3774682 with a big T
also dated J 1 59.
Based on all this I think this engine was in a 60 (car or truck) made at the tonawanda plant.
MAkes more sense now.
This vette has a VIN # 02458 which in my thinking is early since there were like 9500 made. This would tell me it was Jan. or Feb. or some early date.
The engine casting date is K 3 59 which should be NOV.59
Pad is TI209 which is Dec.
I wouldn't expect to find all these late year dates in a early car??????
Bingo????????
Old Nov 15, 2007 | 10:54 PM
knight37128
also dated J 1 59.
Bingo????????
You need a year earlier dates. Nov or early Dec of 1958 casting dates.
I have December 26, 1958 for your cars birthday.
Old Nov 15, 2007 | 11:42 PM
mwm1959's Avatar
mwm1959
How did you determine that date????
Old Nov 15, 2007 | 11:46 PM
knight37128
http://www.c1registry.com/index.php?...lator&uid=1241
Old Nov 16, 2007 | 12:38 PM
JohnZ's Avatar
JohnZ
Bingo????????
That's because the engine was originally a 1960 283/170hp 2-barrel Turboglide, cast and assembled at Tonawanda, installed in a passenger car. The crankshaft has also been changed at some point, as a Turboglide crank can't be used with a manual transmission (or with a Powerglide, for that matter).
Old Nov 16, 2007 | 03:58 PM
mwm1959's Avatar
mwm1959
Thanks for everyones efforts. Ya'll are great.
Does this sound like the right rear end??
Rear End says (3789812 gm P) posi i believe correct for 59.
Anyway here is the long and short of it all.
I bought this car online. Many of you probably saw it on ebay or elsewhere. It was from VAlley Auto and was advertised as correct matching # engine. It is a great 8 or 10 footer with excellent interior.
As we all know now it is not matching #. I contacted them today to tell them my findings. They were extremely nice and said they just looked at the 519 casting. They said they would buy it back OR if I would give them a little time they would get me the correct dated engine,,,have it rebuilt,,,and ship it to me. Sounded very fair to me.
I told them to send the engine. Any advise or thoughts???????????
Old Nov 16, 2007 | 06:39 PM
knight37128
That takes care of the engine. What about the transmission? The Muncie was not made until 1963. A correctly dated T-10 gets expensive................
Old Nov 16, 2007 | 11:13 PM
mwm1959's Avatar
mwm1959
I agree. Not sure what I'll do on that. Maybe nothing. My biggest concern was the engine. I think I'm like most with the engine being the big concern. Anyway,,,I thought that was quite an effort on their part so I guess I'm happy now.
Old Nov 16, 2007 | 11:37 PM
ddsjoseph's Avatar
ddsjoseph
Hi Monty,
I am glad it worked out for you. I am not sure what I would have done if I were you. Good luck with the paint job. If you are going to keep the car, dont think twice about matching #. Just enjoy the car. That's what it's all about.
Joe
P.S.
To engine idetification
Old Nov 17, 2007 | 12:09 AM
mwm1959's Avatar
mwm1959
Hey,,,good to see ya. Yea, I'm gonna play with it awhile, maybe take her to the drive in next spring then in to my shop it goes for a total restore.
Old Nov 17, 2007 | 01:14 AM
mwm1959's Avatar
mwm1959
Ok help me out here?????
How do you know the HP of this motor????? Give it up,,,where's the link? Educate this man!
Old Nov 17, 2007 | 01:19 AM
mwm1959's Avatar
mwm1959
Knight,
If I bought a correct year (58) BW t 10 Trans. will it fit the bell housing I have now?? Or does that have to be changed also since it's with the Muncie? Help a brotha out here!
