Please Clarify
Old Nov 20, 2007 | 09:15 PM
BuffaloBILL's Avatar
BuffaloBILL
Default Please Clarify
Hello members
As you may have read my previous post I had a problem with my Gas tank leaking Well thanks to Speed 55 I now have a brand new Gas tank, I was detailing the undercarriage Being as the tank was out and I noticed that my differential cover numbers were upside down they read 3030383MG (GM 3830303) ON TOP BOTTOM WAS 3MG is the cover on backwards? Can anyone tell me the gear ratio? Also on the driver side of the pumkin ther are some numbers but not legible because of the left side rear strud housing can't see behind it
Any Help (John Z) would help
Happy Thanksgiving to everyone
BuffaloBILL
65Vert
Old Nov 20, 2007 | 09:20 PM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
if you are are under the car looking at the pumpkin there should be a machined pad with a stamp. post thoes numbers. I think you got the pumpkin casting numbers
Old Nov 20, 2007 | 09:24 PM
knight37128's Avatar
knight37128
Please Clarify: What year car?
Old Nov 20, 2007 | 09:42 PM
BuffaloBILL
Default Differential
Sorry
I am facing towards the front of the 1965 Corvette Conv. and these may be casting numbers however the Diff cover stamps are upside down Is this correct or sis the previous owner have the cover installed improperly??
Happy Thanksgiving
BuffaloBILL
1965 Factory A/C Vert
Old Nov 20, 2007 | 09:59 PM
knight37128
Originally Posted by BuffaloBILL
Sorry
Happy Thanksgiving
BuffaloBILL
The cover can not be installed backwards (think of a mirror). Upside down? Maybe, but not backwards.
The numbers for what ratio are on the bottom (where you would put the floor jack).
Old Nov 21, 2007 | 08:46 AM
BuffaloBILL
Default Differential cover
Hello
I NEVER stated that the cover was backwards I my post stated if it is possible for the cover to be UPSIDE DOWN Has anyone had this issue on their Vettes
Thank you
Bill
Old Nov 21, 2007 | 09:10 AM
DZVette's Avatar
DZVette
Bill
The ratio code should be stamped into the bottom edge of the unit along with the date. Here's a shot from the 68 rear that was in my 65. Ratio code is in the box. A0 = 3.70 posi.
Here's a link to some info about codes for 1966 vettes:
http://www.corvettefever.com/images/...ion_codes.html
Hope this helps.
DZ
Old Nov 22, 2007 | 12:50 PM
JohnZ's Avatar
JohnZ
Hello
Thank you
Bill
3830303 is the correct casting number for the rear cover from '63 to early '65, then it became 3871375 (there's no casting date); no, it's not possible to install the rear cover upside-down, or the diff housing would be upside-down after bolting the cover to the crossmember.
The numbers on the driver's side are the casting date for the diff housing. Look at the bottom flange of the diff housing, between the spring plate and the camber strut bracket for the stampings that show the ratio code and assembly date - you'll need to clean it first.
To Please Clarify
