Can someone tell me from the pics attached what year this C2 frame is from. It's currently on a 64 but I've been told it's not the correct frame. Any help is appreciated.
It is hard to tell from these shots, but at first glance, it looks like a mid-year frame at least...or a decent conversion. Look at the first crossmember to see if there is the indentation for the big block balancer/pulley. That will narrow it down to a 63 or 64 frame...that crossmember is unique to those two years. 65-82 frames all had that additional indentation for a big block. Emergency brake and body mount differences will tell you too if it is either a 63 or 64 frame. It may be a converted C3 frame. You can look to see if there is evidence the kick-up braces were removed or the kick-ups were modified for 64.
If you can get more pictures of those areas, others will be able to give you some help.
Here's another pic of what I think is a correct 63/64 frame - I circled the 2 additional (body?) mounts that may telling & are not on the frame in my 1st post above.
I think what I 1st posted may be a 67 frame. Again any help is appreciated.
The pics are from a car I was interested in but there aren't any additional pics of the frame, the frame vin stamp, or the front X member. These were taken as part of a restore that was performed on the car.
what is the person who tells you this is not the correct frame telling you it is from?
They just indicated a later model. They noticed those body mounts were missing but weren't sure which year frame this actually was. This was a car I was considering purchasing & it was advertised as "numbers matching & original" and priced accordingly. I'm no longer interested for the price but wanted to understand the frame differences as I continue looking for a C2.
Could be a '63 or up to a March '64 frame since after that the gussets were added in the corners. The extra mount would indicate it is a convertible made before March '64.
