Date Correct block value to Car
I found what could be a correctly dated 870 block for my very early '62.
Its a pass car block but the cast date is correct - G 7 1. My serial # is 0098.
What kind of value do you think this would add to my car if I ever decided to sell it? As you can see by my avatar, my car ain't too correct now...
Thanks!!!
Pete
I don't think that the price is that bad considering that it is so early in the 870 production run.
Obviously, if I wanted to go all out, heads, intake, carb, generator, distributor, water pump, etc will be a huge amount of money. As i mentioned before, my car is far from original but certainly it could be brought back if someone was so inclined.
Is it worth putting $1,000 into the "engine core bank" for some rainy day? That's my question.
So? What do you guys think with this new info?
Thanks again!!!
Doug
It is a bare block, currently at .030. A crank and rods are $100 extra. No measurements on those yet.
He gaurantees it to clean up at .060.
I have to believe, based on my initial serches, that this block is pretty rare. I have only seen 2 other 870 blocks dated earlier than December of 61 in about 20 years of being an enthusiest (layman's term for Vette nut).
An 870 block from another 62 vette with an appropriate assembly date and usage code for your car, but someone else's VIN would get you most of the engine points at the NCRS.
An 870 block with a passenger car use SEEMS like it would be of almost no value to anyone other than a restamper.
Since you aren't trying to restore the car, I think it'd make more sense to pass on this
The only thing that concerns me is when was your car made? The black book shows 443 cars made in August and ending vin # 827 in September ( 827-443= 384 cars for Sept.)
Now Aug had 23 work days with no Saturdays or Sundays, and Sept had 21 days, less Labor Day holiday = 20 days. So 43 days for 827 cars or 19.23 cars per day. If so, vin # 20867S100098 WAS MADE ON THE 5TH PRODUCTION DAY IN AUGUST 1961. Question is, When did they start production ......Tuesday, August 1 ? Monday August 14?
August 10 (THIS ENGINE ASSEMBLY DAY) was a Thursday, and generally Corvette motors are built about one to two weeks in front of their actual car assembly date. So, if we look at one week, then your car will have to be made on Thursday AUGUST 17, 1961 to fit this engine. We need to find a 62 Corvette freak to verify your actual build date of your car before you spend the money.
I love the engine and agree, a July 7, 1961 cast date is impossible to find. It is interesting to see a July 7 cast vs. August 10 assembly. That's 4 weeks. I have seen engines with one and two days between cast and assemble.
I would buy it anyway, because you will never find any better. Don't worry about pistons and rods. There are new items available today that are better quality and not a lot of money.
I would however demand that engine be mag checked for crackes and get the machine shop to say AOK on bore and clean up, before I spent the money.......even if I had to pay for the tests.
By October, last vin was #2065 and #3465 for November. So production increased to 50-65 cars per day.
My guess, and perhaps someone can confirm this, but they started casting engines and parts a few weeks earlier than the car production run started. So i think a 4 week lag between casting date and assembly date is OK in this scenario.
As for the quality of the block, having it checked out is part of the plan.
We all know the engine is a pass car block, so either its a correctly cast dated pass car block or its a Corvette restamp, in which case it will have the correct assembly date anyway.
My goal is not to pimp someone into believing they are buying a correct numbers matching car someday, but have the OPTION available to build as correct a car as possible someday for someone.
Personally, when I replace my front clip with an ACI or Shiemershiem's, I will probably shave the front bumpers again to keep it like it is. I will probably never sell the car unless the Michigan economy gets worse
so its really all for my kids or whomever might offer me way too much money to allow me to buy something that I might like better.So, the question still remains in my mind, is $1,000 worth putting into the back corner of my garage for (hopefully) many, many years to gain something back??
especially, the "satisfies me" part.
