Sanding sequence
Old Jan 7, 2008 | 10:35 AM
orthokenneth's Avatar
orthokenneth
Cruising
Default Sanding sequence
'66 Vette is bare glass. What grit do you use on the glass to get a "tooth" for Gelcoat?
Old Jan 7, 2008 | 11:08 AM
flynams's Avatar
flynams
flamesuit is on, but here goes....forget the gel coat...sand with 180 and 2 coats of SPI epoxy...
Old Jan 7, 2008 | 12:38 PM
Auto5's Avatar
Auto5
I'm with flynams...then 2 coats Slicksand w/2.2 fluid tip/guide coat - block 180, 2 wet coats 2K primer - final block-600 wet, then you should be good to go.
To Sanding sequence
