Help needed de-coding block #'s
Old Jan 12, 2008 | 02:19 PM
TeamTruett's Avatar
TeamTruett
Default Help needed de-coding block #'s
The engine is not original as my dad had it replaced in '76 when he was going to rebuild it and the cylinder walls were deemed too thin. (who knew that matching numbers were important back then?) I wondered what info can be taken from the replacement engine. It's not a corvette engine and my dad thought it might actually be from a truck!So we are curious as to where this engine came from. I noted the following numbers
front left pad: T0I04MK The "I" might be a "1"
cast # 3903352
"L 29 6" on top of where bell housing bolt would thread into
also "CONV1" is cast on opposite side
Can anyone crunch these numbers?
Old Jan 12, 2008 | 02:35 PM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
3892657 is a 302/327/350 that is a 64-67 with a rated hp of 210-350 and was used in a car or Truck 2-bolt
go here for more http://www.chevymania.com/
Old Jan 12, 2008 | 02:44 PM
Black_Magic's Avatar
Black_Magic
2020 Corvette of the Year (appearance mods)
C2 of Year Winner (appearance mods) 2019
CI 4-5-7-9-10-11 Car Show Winner
CI 2-3-4-5-6-7-9-10-11 Vet
Old Jan 12, 2008 | 08:17 PM
TeamTruett's Avatar
TeamTruett
correction it's cast # 3903352 thanks for the link
JohnZ's Avatar
JohnZ
cast # 3892657
"MK" was a '67 Camaro L-30 (327/275hp 4-barrel); yours was cast at Tonawanda on December 29, 1966, and assembled there on January 4, 1967.
Old Jan 12, 2008 | 09:21 PM
TeamTruett's Avatar
TeamTruett
Thanks for the decode! Wow thats only a month before the final assmebly of the car (feb 10 1967). On the front pad, there is no VIN number stamp, only "T0104MK", is that unusual?
Old Jan 12, 2008 | 11:15 PM
Sundevil64's Avatar
Sundevil64
Default codes
http://www.nastyz28.com/chevy-engine-code-stampings.php
Old Jan 13, 2008 | 02:04 AM
knight37128's Avatar
knight37128
Very unusual.
The motors for corvettes were assembled in Flint not Tonawanda.
Old Jan 13, 2008 | 01:31 PM
TeamTruett's Avatar
TeamTruett
I went image searching for some Camaro engine pad stamps, no VIN number stamps.
http://www.investmentmotorcars.net/i...7rs/detail.htm
http://www.stratagaz.com/67L30M20/L3...ngineStamp.jpg
Old Jan 13, 2008 | 01:52 PM
Nowhere Man
alot of the low horse power small blocks out side of vettes were not stamped.
Old Jan 14, 2008 | 01:01 PM
JohnZ's Avatar
JohnZ
Nope, not unusual - only the SS (L48), Z/28, and 396BB's had VIN stamps on the block in '67 Camaros. The engine assembly date you have is a coincidence - Tonawanda small-blocks weren't used in Corvettes.
Old Jan 14, 2008 | 01:03 PM
TeamTruett's Avatar
TeamTruett
Thanks for all the input guys
To Help needed de-coding block #'s
