replace shifter
Old Feb 12, 2008 | 03:18 PM
mikey b's Avatar
mikey b
Default replace shifter
the picture attached is of the shifter that is currenlty installed (it came witht he car)
i woudl like to change it, and have a few questions
1) is this sometign i can do myself?
2) how complacated is it to relace?
3) where can i purchase a new shifter? how much do they run?
Old Feb 12, 2008 | 03:22 PM
wmf62's Avatar
wmf62
St. Jude Donor '07
the shifter is very easy to remove (just a couple of bolts) from under the car; and rather than replacing it, i think you can still send it back to Hurst and have it rebuilt (that would include rechroming the stick)
Bill
Old Feb 12, 2008 | 03:25 PM
Crazyhorse's Avatar
Crazyhorse
Do you want to just replace the stick or the whole unit?
Old Feb 12, 2008 | 03:46 PM
mikey b's Avatar
mikey b
I do not know?
at first i wanted to put in an origional shifter witht he t lock
i saw it in a catalog for ~300 or 399 (cant rember)
now i am thinking abotu just changing the stick since it looks so bad.
why woudl i want to replace the whole unit? if it did not shift correctly?
Old Feb 12, 2008 | 03:47 PM
mikey b's Avatar
mikey b
how much would that cost?
hwo woudl i go about doing that?
Old Feb 12, 2008 | 03:55 PM
mikey b's Avatar
mikey b
Bill
I found the website and the rbuild service ,, i think $250 for OEM shifter
the couple of boltd is that to remove everything or just the stick ,,, can i just remove the stick? and replce it . or get it rechromed?
Old Feb 12, 2008 | 03:59 PM
Crazyhorse's Avatar
Crazyhorse
Yes.
Looks like you've got some dusting to do, what's the story with the car?
Old Feb 12, 2008 | 04:11 PM
mikey b's Avatar
mikey b
Originally Posted by Crazyhorse
Yes.
I purchased the car jan 2007
got it running and sent it in to get painted (just finished yesterday )
it is stil in the paint shop
i will post pictures once i get it home
so is it a couple of bolts to either remove the entire assy or jsut the stick ? either is just as easy?
Old Feb 12, 2008 | 04:43 PM
Mike Geary's Avatar
Mike Geary
Default Your Shift Lever is Integral to the Assembly
Your unit is the old style Hurst with a welded on lever.
You need to unbolt the whole shifter from the tailshaft, unclip the rods from their shift dogs and drop the whole thing down.
Later, Hurst changed their design to a shift lever that bolted onto the shifter assy.
Old Feb 12, 2008 | 05:40 PM
DZAUTO's Avatar
DZAUTO
2026 Corvette of the Year Finalist - Modified
2025 c1 of the Year - Modified Winner
2024 C1 of the Year Finalist - Modified
2023 C1 of the Year Finalist - Modified
2015 C1 of the Year Finalist
Mike is correct.
There are REPLICA shifter handles available for your car that are made to bolt up to a Hurst shifter.
All that you SHOULD need is ONLY the shifter, no mounting hardware or shifter rods. Corvette Central carries the replica handle.
Old Feb 12, 2008 | 05:49 PM
64roadster's Avatar
64roadster
St. Jude Donor '07
Bill
I sent the shifter in my '68 Z28 to Hurst for a rebuild, years ago.
Old Feb 12, 2008 | 06:01 PM
BADBIRDCAGE's Avatar
BADBIRDCAGE
That's a C-1 and as mentioned in an earlier post you have a welded unit for the shifter handle and you can't bolt a replacement on it anyway.
If you send it in for rebuild they might be able to replace the welded on unit with a bolt on unit in which case you could use a replacement handle on it.
Otherwise you could purchase a new unit with the bolt on type handle.
Rich
Old Feb 12, 2008 | 07:50 PM
62Jeff's Avatar
62Jeff
Bummer, hope they return it soon
Old Feb 12, 2008 | 07:54 PM
Road-Race Vette's Avatar
0Road-Race Vette
Former Vendor
That, my friend, is funny
Old Feb 12, 2008 | 09:05 PM
Blk63Vette's Avatar
Blk63Vette
Default 1960's HURST Shifter
Hi
I had a stock looking shifter that was used with a HURST linkage I switched to the one you have there...I personally like them better (I kinda think its more "manly")..I bought one and had the stick rechromed by Pauls Chrome Shop...I had the unit sent out to be rebuilt by HURST..I think your shifter comes out as one unit...Looks like a 1960s model HURST shifter....Plus popular upgrade back in the day...
Good luck
Old Feb 13, 2008 | 12:10 PM
mikey b's Avatar
mikey b
Default thanks
to all
thank you for your responses
looks like i have 2 options
1) purchase a new shifter assy
2) remove the one i have and send it to be rebuilt by hurst and rechromed
Old Feb 13, 2008 | 04:17 PM
sub006's Avatar
sub006
A stock-looking lever and **** controlling the superior Hurst mechanism under the floor would seem the best of both worlds.
To replace shifter
Old Feb 14, 2008 | 08:59 AM
66BlkBB's Avatar
66BlkBB
St. Jude Donor '13-'14-'15-'16-'17
Just a question here. Wouldn't it be just as cheap to buy a new Hurst shifter with the bent handle for this car. Sending out for a rebuild and re-chroming the shaft are not going to be cheap, are they??? Would think that cost of rebuild, re-chrome and shipping would be close if not over the cost of new shifter.
Steve
Old Feb 14, 2008 | 03:45 PM
mikey b's Avatar
mikey b
Steve
it seems the cost to rebuild with chrome will be about $240 +shipping
a new compitition plus shifter is $460 + installation kit.
the rebuild service takes 4-5 weeks.
the only problem is (since thsi shift stick is welded in place) if i choose the rebuild i will not have the flexibility to put n stock looking stick in the future if i want to with out replacign the entire shifter assy then.
Old Feb 14, 2008 | 03:46 PM
mikey b's Avatar
mikey b
i agree,,, the cost just keeps going up
