I finally took my frame apart to have it blasted and painted. I left the rear suspension all together but I plan on tearing it down and redoing it (all of the rubber parts, shocks, etc.). Now my question is how do I change the rear spring cushions? BTW, I'm leaving the leaf spring attached to the diff. Is this tricky and easily done by myself? Should I have left the diff. on the frame or wait until I mount it back on the frame and rebuilt everything from there?
BTW, I did a search on leaf springs and read a bunch of posts but none, that I could find, said anything about changing the leaf spring cushions while attached to the diff.
It sounds like he means the leaf liners. If so, the spring has to be unbolted from the diff. and follow the basic process of removing the center bolt, cleaning and painting per your own requirements and reassemble with the new liners. Dennis
By "cushions" do you mean the liners inbetween the spring leaves, or the round cushions on the end link bolts to the trailing arms?
Sorry guys!!! I meant the round cushions on the end link bolts. I'm not planning on removing the leaf spring and redoing it....I'm assuming the leaf spring is in good shape. When I looked at the leaf spring the liners looked okay (from the outside parts I could see) but they are a cracked in a few places....assuming that is normal.
I'm confused. What state is your car in? I read that the differential is out of the car and the spring is still attached to the differential. To do that, you had to take the end link bolts out already, so the cushions are out already??????????
Sorry again!!! The body is off of the frame and the frame is stripped of all of it's parts....ready to paint it. I took the differential off with the wheels and all attached (including not removing the end link bolts)....probably not what I should have done but I did. Would a picture help?
Thanks,
58n65
Yes, a pic would help. I assume you are working on your '65? When your body was on the car and everything was assembled, was the spring flat or did it have some arch to it?
As for taking the outer bolts off, yes, you should have done it with the weight on the suspension so you could compress the spring to take the bolts off. Now you have a bullet if you torch it or you need to compress the spring to use tools.
I did the exact same thing ! Now I too am trying to figure the best safest way to do this cause I know there is a lot of force there. I'll look at it today and see if something comes to me.
I'll try to get a picture tonight or else it'll be friday morning. When the body was on it seemed to have an arch but when the body was off the wheel on the driver's side wa cocked at an angle but the passenger's wheel was straight....is that normal?
58n65
This is off the subject.....but if you can, have the frame powder coated. You will never regret it as it is so much superior to paint. That is unless you have a means for dipping the frame in epoxy primer first....then I would go with paint.
I don't have a powder coat setup and I'm not really sure how to do it. Besides my Dad's a Painter and he wants to help out.
How tight are the outer bolts? They don't look like they are under a lot of stress right now since the outer suspension at the wheels is compressed "down" and away from the pig. If you can turn any of those washers or just turn the bolt in the trailing arm easily by hand or with a wrench, I would just take them off carefully. Otherwise I would torch them off from the middle and aim them in a garbage can or bucket.
Torch the bolt above the spring so the force goes away from you but you should be ok. I have torched the bolts before when they are under full stress while in the car. They don't bounce too high!!!
In the photos, I notice some additional washers that have been used as spacers between the rubber biscuit and the end of the the leaf spring. These would be added to raise the height of the rear of the car. This could mean that the leaf spring is sagging or worn out.
Just my 2 cents.
Mark
Thanks TopLess. That's a good idea to try to turn either the washers or the bolts. I'll tryit either tomorrow evening or friday morning.
Just my 2 cents.
Mark
Mark,
I noticed on the front coil springs that there was a piece stuck between the coil spring to keep it from compressing all of the way. I was wondering if that was due to the different rims and tires the previous owner put on the car? I was told that the guy was going to race it. BTW, I bought the car from my friend's dad who bought it from the previous owner I mentioned above. Maybe he raised the height on purpose???
Either way I wonder if I should change the leaf spring....what a pain to figure out.
Just my 2 cents.
Mark
In my first Corvette many years ago and I was full of good ideas I did the same thing to remedy a sagged spring. The spring broke soon after that.....
Are you building an NCRS 100 point car? If not, get a new spring, I think they are about $125 to $150 and well worth the aggravation to change now while you have it apart. I forgot to mention the washers in my post as others have. Get new hardware and cusions as well. ITs not worth playing with for the price and the headache.
Nope building this car for driving. The NCRS thing would be nice but I'm missing the original motor....besides I'll probably never have it judged....building it for my daughter's graduation present. Good suggestion, I think I'll go ahead and replace the leaf spring while I have everything apart. Now that brings me back to my original question - how hard/safe is it to remove the end link bolts and are there any techniques to do it while the assembly is off of the frame?
