1963 Corvette Inner door knob question
Old 02-27-2008, 02:59 PM
Blk63Vette
Blk63Vette's Avatar
Default 1963 Corvette Inner door **** question
Hello
I noticed the inside **** (black plastic ball) on the passenger side is loose. I first thought that the **** needed to be tighten (screwed) but it is tight on post. The post that goes into the mechanism (latch appears to be "X" shape with a smal spring in center) is loose. I have never taken off the door panel before on this car. My question, is there a screw on the back of the post that can be tighten, or is the post riveted to the latch?
Pete
Old 02-27-2008, 03:31 PM
jbfc2
jbfc2's Avatar
I think you'll find that most of them are loose. I don't think it can be tightened. I put a piece of foam behind mine so when the door panel is on it makes it a tighter fit.
Old 02-27-2008, 04:36 PM
Chuck Gongloff
Support Corvetteforum!
Chuck Gongloff's Avatar
If you take it apart, you can tack weld it.
That's what I did. Tack weld it behind so you can't see the weld.
I believe the "post" is pushed/swedged in.
Chuck
Old 02-27-2008, 04:53 PM
rene-paul
rene-paul's Avatar
I have an old old article that has a cure for your problem. If you want I can search my archives [boxes of vette mags] and fax it to you. Chuck is right on, the article will provide the details. BTW the return spring is available and should be replaced also.
brgds
rene
Old 02-27-2008, 04:56 PM
Blk63Vette
Blk63Vette's Avatar
brgds
rene
Im curious as to who sells the return spring?
Old 02-27-2008, 05:38 PM
AColbe01
AColbe01's Avatar
Chuck
Received a new one in from ZIP, the shaft on it was loose also, put a couple of jamb nuts on it to protect the threads and peened the shaft tighter to the metal. While you're in the door is a good time to check the door latch assembly. Over time there is a small finger that will wear away and make you have to pull further on the door **** to release the door.
This thread covers more of the latch possible issues (Less frequently will happen to passenger door) http://forums.corvetteforum.com/show....php?t=1718762
Good Luck,
Andy
Old 02-27-2008, 05:54 PM
philip964
philip964's Avatar
On a '63 the door chrome ball is supposed to be black? Next you'll tell me the Stick shift ball is supposed to be black too! At least my console plate is black.
Old 02-27-2008, 10:55 PM
blubu
blubu's Avatar
Default answer
Yep it is only 63 Hell I put mine up and used chrome ones anyway
To 1963 Corvette Inner door knob question
Quick Reply: 1963 Corvette Inner door knob question
