bolt pattern question
Old Mar 17, 2008 | 10:16 AM
remotecontroller's Avatar
remotecontroller
Default bolt pattern question
Hey guys,
Probably will seem like a silly question, but what are the actual bolt pattern measurements for a C1 (I have a '58)? Some of the stuff I have seen even says that the measurements aren't actually what the rims are called. I thought C1's hada a 5 by 4 1/2" bolt pattern, but have also seen a 5 by 4 1/2 "ford" bolt pattern. Is this pattern usable on a C1?
I looked through the archives and the internet and can't find anything consistent......
Thanks!!!
Old Mar 17, 2008 | 11:25 AM
6T5RUSH's Avatar
6T5RUSH
Cruise-In III Veteran
remotecontroller,
Not into C1's but for measuring wheels you may come across in general, this site could be helpful to you:
http://crankshaftcoalition.com/wiki/..._wheel_pattern.
Read down on this site for specifics on GM vehicles.
Hope this helps.
Regards,
Jim
Old Mar 17, 2008 | 11:36 AM
remotecontroller
Originally Posted by 6T5RUSH
remotecontroller,
Hope this helps.
Regards,
Jim
Thanks Jim,
Very helpful. On the link, in one area it shows measuring to a line drawn between 2 on the holes on a 5 lug and further down it says measure to the outside of one of the furthest away lug holes. Won't this create a different measurement or will the measurements be close enough to not matter?
thanks,
Ken
Old Mar 17, 2008 | 11:46 AM
6T5RUSH's Avatar
6T5RUSH
Ken,
Apparently, when you are measuring the 5 lug wheels, you would measure from the outside edge of 1 lug hole to the opposite lug hole center line. Here's Tire Rack's web site confirming this also:
http://www.tirerack.com/tires/tirete....jsp?techid=92
Regards,
Jim
Old Mar 17, 2008 | 11:56 AM
JohnZ's Avatar
JohnZ
Originally Posted by remotecontroller
Hey guys,
Thanks!!!
All Chevy C1/2/3 wheels are 5 x 4-3/4".
To bolt pattern question
