Right door lock problem ?
Old Mar 25, 2008 | 01:54 PM
stormydog's Avatar
stormydog
Default Right door lock problem ?
Hi, Having a problem with the right door lock assembley, putting it back in after painting. All seems to work well outside, everything is good and clean,and loose. I put it back in ,it Locks up as if it is in a bind, I loosen all the screws, it works fine.What is it I am not seeing ?....Am I missing a spacer? All help is welcome. Thanks for reading!
Old Mar 25, 2008 | 07:16 PM
62Jeff's Avatar
62Jeff
Well, since you haven't gotten any replies yet, here's a bump to the top, as well as a suggestion - do you have the lock in upside down? I seem to remember someone here found their door locks were stiff, and it was because the left lock was on the right side and upside down, and the right lock was on the left side and upside down.
Don't have a CLUE if that really happened or if I dreamed it
Old Mar 25, 2008 | 07:18 PM
DZVette's Avatar
DZVette
What year car are you working on?
DZ
Old Mar 25, 2008 | 09:46 PM
stormydog's Avatar
stormydog
Sorry, 1967 conv.
Old Mar 26, 2008 | 10:27 AM
stormydog's Avatar
stormydog
Thanks for the bump !
Old Mar 26, 2008 | 11:31 PM
stormydog's Avatar
stormydog
one more bump
Old Mar 27, 2008 | 05:11 PM
macs65's Avatar
macs65
the locks are specific for right and left side. It is very difficult to get the slider that holds the lock (inside the door) in place if the locks are reversed, but right side up. Not sure if the slider would be as difficult if the lock is upside down.
To Right door lock problem ?
