console
Old Apr 5, 2008 | 12:29 PM
Nacman's Avatar
Nacman
Default console
I'm not sure of the material, But the trimming on the console is pretty beat. Does anyone make the leather or simulated whatever it is piece for a 64 4sd console that can be just glued in.
Old Apr 5, 2008 | 01:05 PM
JohnZ's Avatar
JohnZ
The grained/textured portion isn't added on - it was cast-in as the surface when the console was made.
Old Apr 5, 2008 | 01:49 PM
dkleather's Avatar
dkleather
2016 C2 of the Year Finalist
If your console has some material on it besides paint a previous owner probably covered it with something. The original was chromed cast with a painted insert that is under whatever you've got on yours. Mine had some type of vinyl cover on the insert when I got it which I removed, stripped the paint underneath and redid. Yours might be the same.
Old Apr 5, 2008 | 08:22 PM
Nacman's Avatar
Nacman
Default Thanks
I was able to talk to a guy in town that has a few C2's and he said the same thing. Strip it out and clean it up and paint it, because it did not come with an insert it was just painted. Thanks
To console
