I have a 327/300 64 vert that I have had for 30 years.. In the last several years it has had an occaisional starting problem (slow turning over).
What happens is that some timse when I stop for gas or other quick stops when I go to restart the engine it turns over very slow like the starter/battery is too weak. (or way too advanced??) If I continue, it starts but doesn't leave you with alot of confidence for the next time...
I know the battery/ and starter are in good shape, because when I haven't started the car in a few weeks I usually have to crank it a while and it does that just fine...(with plenty of pep)...
I have basically have a stock motor with a mallery pickup (vice points) and an MSD box (6a I think)...
Since it happens only when the car is hot, my initial reaction would be corrosion on one of the connections: Battery cables, bulk-head connector, starter.
I have the same exact problem with my 65. I have a new Optima and new cables that I will be installing this week along with cleaning all of the connections so will update as to whether that solved the problem. It is kind of disturbing when you stop and know that the engine is going to crank slow ( haven't got stuck yet but very uncomfortable feeling)
Bill, hot starting problems can also be caused by cooling problems that allow your engine to run too hot (the pistons swell up and may scuff the cylinder walls), OR (And Most Likely)
excessive resistance in the starter motor that causes the engine to crank slowly. A starter "amp draw" test can be used to check the condition of your starter.
I had this slow-turnover-when-hot problem when I was running my original 327 engine. I discovered that I was missing a small heat shield that protected the starter from heat radiating from nearby exhaust pipes and manifolds. If your shield is missing, the starter may get too hot and bind up. When I was running the 327, I also ran a lightweight solenoid spring, going from memory, I believe it was ACDelco Part # 1958679.
Have the starter fields and armature checked for shorts/opens. Clean up the commutator and put in new brushes, bushings and lube. put the starter back on and you should be okay.
It will suprise you what just a good clean up and lube will do for a starter motor. No parts required in many cases.
- Pat
I don't even own a Mid-Year, but am quite familiar with small blocks' behaviors/tendencies. I'll put money on something related to the above. Countless small blocks in Camaros & Vettes that I've been around have had this problem. It's always "when hot". While I can't opine on exactly what happens to the starter inside when it's hot, I do know that it will turn over as if it does not have a enough battery power. Combine this with a higher compression motor, and you've got a recipe for "fingers crossed" starting when hot.
Thanks for all the suggestions and ideas... I was thinking it had to do with too much advance initial/or vacume advance, but it sounds like it is more of a starter/heat sink problem... I do have a fairly new raditor and heater core and pump/fluid.. I'll check connections, then focus in on the starter with a going over or a replacement...
5thvet, if you solve the problem, please be sure to post the results....
Thanks to all.... It just gets a bit embarassing some times when a beautiful car with folks watching cranks up like a real piece of .......
Lots of replies TODAY about heat causing the starters to drag when the engine is hot. Well, YESTERDAY when the starter motors were NEW and CLEAN, they didn't drag when the engine got hot. They'd spin just about as fast hot as they would cold.
I don't doubt the starter motor internal resistance increases with heat but that is not usually the root cause of the slow cranking problem.
So much for wrapping the exhaust, heat shields and all this other stuff that treats the symptom rather than the cause.
My 62 did the same. Today I removed the starter. Cleaned it. Oiled the bearings and used 2000 grit paper on the brushes. Built my own temporary heat shield of tin. My battery had two post terminals on each post one regular and one wing nut. I cleaned both ends of the cables and added a 4 guage (extra) cable from + post wing nut to starter. Drove it about 45 min. Restarted several times then parked it for 15 min. she started right up... My fingers are crossed. THANKS TO ALL!!!!!
