'62 Dash Pad Install
Any help would be greatly appreciated.
1. Take your time.
2. Don't trim anything until you are sure.
3. Take your time.
4. Line it up several times and make sure it fits well. You should not need any glue.
5. Take your time...
6. If possible get someone who has done one to help you. One of the most difficult things will be to put the pod back in.
7. Pay close attention to the corners on both sides, they need to line up well.
8. You will need 2 people to do this and one of you will have to climb under to install the pod....it is not an easy job but will look great when completed...
I realized this is not great information but I hope it helps...
Good luck, John
Jim
Here are some pictures of how to cut the pad when installing.
Take your time, test fit over and over again!
I personally did the test fit of the Corvette America dash pads (pictured) and also helped them in making adjustments to the current production of the dash pads.
You really have to be careful when you remove any foam from the pad! If you remove to much the pad will not fit properly and fit horrible.
When you glue the pad, you want to glue the edge under the windshield frame. There will be an lip there and it’s a good idea to make slices in this lip so you can fold it over to fit under the windshield frame. The original GM pads did not require this, but they were a made with the lip made a little flatter than any reproduction.
Problem areas during the installation are behind the dash cluster and the passenger side dash insert. (Both are foam related).
Also the center of the dash pad right in the middle may need to have some foam removed. The key is to remove as little as possible and then test fit. Then remove more if needed.
Do not cut the holes for the defroster and radio speaker until you have the pad in the car and done!
Three years ago, we installed so many pads that if you have any problems, email me at willcoxcustomerservice@willcoxcorvette.c om
I hope this helps and again if you have any problems, just email me. I’ve installed original GM pads and the reproduction pads. Both are not easy, but it’s something you can do if you take your time.
Willcox
Again,JP
Have fun...it would be great if you could keep us posted regarding your progress...
Again,JP
I will say this again, you need to have someone push with both feet like hell on the dash cluster to get it in the right position so that you can get the fasteners in place......did I say push like hell? with legs?
good luck!
