Jay Leno's E85 Corvette
Old May 14, 2008 | 03:00 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
Originally Posted by macdarren
Could the US in theory grow enough of what ever this product is to provide all or our fuel energy, including that energy would be required to grow the crop and produce the fuel, anytime in the near future? What about just enough that coupled with our own petroleum resources would it be enough for total independence?
The numbers I've seen have varied widely, but odds are with some new deposits opening up in Canada, the Dakotas and Brazil (as well as ethanol imports from Brazil), the use of more efficient ethanol sources such as cellulose would go a long way towards getting the US away from buying oil from unfriendly sources.
And a more general question...what is the typical octane rating of e85? Time for some more google searching I think.
100-105, depending on the source material and exact composition of the mix. http://www.iowacorn.org/ethanol/ethanol_5a.html
I've read some anecdotal reports that while most e85 hovers in the 103-107 octane range, it behaves like 110-112 when being burned in some applications, apparently due to the cooling effect of the alcohol.
As an update to an earlier post, the stoichiometric rating of e85 is apparently 9.76:1.
Old May 14, 2008 | 03:24 PM
Dad's '66's Avatar
Dad's '66
Batman,
Checking to see if I am tracking with you.
Is it your theory that because of the higher octane rating, you can use a much higer compression ratio, making more power, thus being able to use say taller gearing to make up for the added fuel that is needed because of the decreased A/F ratio?
If that is the case, then couldn't you use 110 gasoline, with the same changes to utilize the octane to its full potential and get better mileage with the gasoline, because of the increased A/F ratio?
I have nothing against E85, just trying to learn about these alternate fuels, and understand what the real impact/benefit is.
With my experience with methanol, fuel efficiency has never been a thought, as with our application, we would be measuring it in GPM's (gallons per mile ).
The Joker....
Old May 14, 2008 | 08:52 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
Originally Posted by Dad's '66
Batman,
The Joker....
Changing gearing to stay in the engine's most efficient powerband would be the most efficient way to go with a carbed engine, with EFI you could probably just not put the foot as deep into the go-pedal.
Obviously 100+ octane gasoline is going to produce even more power than e85 at those high compession ratios, but 100+ octane gas is only available as leaded aviation fuel and is quite expensive. In a lot of areas, e85 is cheaper than 87 octane regular.
There's a lot I don't know about this, and so far for me it's all theoretical. I've been doing a lot of research lately, though, as I've been seriously considering taking advantage of the ready availability of e85 in this area.
