putting emblems on a C2
Old May 11, 2008 | 08:17 PM
joec's Avatar
joec
Default putting emblems on a C2
Ok, so I FINALLY got my car back from paint (it was way to long, please don't ask) and now some of the holes for the emblems are covered over with paint and who knows what else... What is the best way to open up the holes??? Drill???
Old May 11, 2008 | 08:56 PM
62Jeff's Avatar
62Jeff
I would use the smallest drill bit in a hand operated drill, to drill through the center of the hole from the back side.
Then using that little hole as a locating hole, use a larger drill bit from the front side, again in a manual drill (not electric) to slowly enlarge the hole.
I had to do this on my 62 when we forgot to have the emblem holes opened up prior to paint. They had been filled in a previous life, and I got to open them after the car had the new correct paint on it.
Old May 11, 2008 | 09:08 PM
67vetteal's Avatar
67vetteal
Joe, Using a small drill and progressively opening the holes is good advice. And, I never use the mechanical fasteners to hold the emblems on. You will find that a dab of weatherstrip adhesive on the emblem posts before insertion keeps them in place. This way when you wax the car they can be removed to keep from having white paste in the details of the emblem. Al W.
Old May 11, 2008 | 09:14 PM
joec's Avatar
joec
Thanks Guys!! Thats what I was told by a friend also (not that I don't trust him.. ) Much appreciated..
/joe
Old May 11, 2008 | 10:55 PM
nitromainia's Avatar
nitromainia
It's been a while, but I've used the drill in REVERSE -it's not as likely to chip....
Old May 12, 2008 | 05:33 AM
Olustee bus's Avatar
Olustee bus
Veteran: National Guard
Mine were filled with bondo and we just used a drill bit, twisted by hand from the backside.
Old May 12, 2008 | 12:25 PM
JohnZ's Avatar
JohnZ
Use masking tape on the outside surface so you don't lift paint surrounding the holes.
To putting emblems on a C2
