Ok, I rebuilt the headlight motor, cleaned and greased, put it back together and nothing. It worked before but was really slow. I checked to make sure it isn't binding. Checked the plug and it's getting power. What did I do? Ant way to check it out of the car? Thanks
Good grief. You built the thing and didnt check it before you put it back in? All you have to do is ground the case and touch the terminals with the positive wire off a battery or charger. One makes the motor go CW and the other CCW.
if you know your getting power to the motor, I would look and make sure that the brushes are good or on correctly.. That's where I would start.. If I'm correct, someone else stated you can use a battery charger.. Ground to the case and power to the motor tabs...
Also, although I don't understand it, mine won't work unless the headlight alarm wires are properly connected to their switch next to the motor.
I bet he's missing the ground. However the switch next to the motor has nothing to do with operation. You could leave them disconnected and it would not make a bit of difference. They are only tattle tail switches.
Exactly. And that's why I get confused when I see that my headlight motor behavior is seemingly dependent upon the integrity of those tattle tail switch wires.
Made sure the black ground wire was connected to the frame in the nose and the casing of the headlight motor. Might have got some grime or something on the brushes. Will take it apart, clean the brushes with alcohol and see what happens. Can I just use a 12 volt battery to check it off the car? Ground the body to the ground on the battery and use the hot to either of the motor terminals?
That's exactly the correct way to test it out of the car.
Good luck in resolving your concern. Chris
Always run 'em on the work bench before putting them back in. Run foreward and reverse for 4-5 minutes each way. They will get very hot. Seats the motor brushs and polishes the commutator.
Hope you didn't use an over long #10-24 screw for the brace/ground wire. A long screw there and you short out the field winding.
Thanks guys, some good information here. I will check the ground screw length, and check it with a battery. If it still doesn't work, I will open it up and wipe the brushes with some alcohol to make sure my dirty hands didn't contaminate the brushes while putting them back together. Yep, will double check to make sure I put them back in the correct position too. My eyes aren't that good anymore.
The other motor was rebuilt recently but makes kind of a screeching noise while turning the headlight bucket. I checked the bucket when the motor was out and it was free and no noise. Any ideas? I don't think it's the motor but maybe the bar that keep the motor in place?
You could also try backing off the two screws that hold the motor housing on. Sometimes the first time you start them up it helps that they're a little loose. Once it's running you can snug them up again.
Ken,
I've done mine recently and had an awful lot of trouble with the left hand headlight turning real slow. The motor sounded as though it was struggling both before the rebuild and after.
The problem I found was a combination of two things. The end float of the motor shaft and also the thickness of the washer behind the bellville washer on the main output gear. I used a thinner washer here - about half thickness of standard. I found that the standard washer jammed the pot metal gear when the casing was screwed together tight - don't ask me why. Now both motors open quick and together
Ken,
Nev,
I was wondering about that also. I don't know why there is a thick washer and a convex washer. It would seem the one convex would be enough to make good alignment with the worm gear. I might try removing the thick washer and see what happens.
Ok, that was the problem. I loosened the 2 screws up and it spins very fast. Still makes a screeching noise as does the other one that was already re-built but it turns very nice. Now I am afraid to tighten the case back up for fear of binding. Maybe I need some kind of home made gasket for the housing? Any suggestions on getting ride of the screeching noise?
The screeching is probably a lubrication issue unfortunately. It's probably in one of the rotor bushings. They need to be cleaned really well and lubricated with a little lithium grease (or whatever).
If you can run the motor while tightening the two housing screws you can get the the optimum bolt tightness.
These motors are essentially the same as the 65 66 power antennas. I've done a ton of those and have seen most of the problems.
Well, both motors are now installed and working. I am going to ignore the screeching because I don't use headlights much since I usually don't drive at night. BUT, if I need to I now have working headlights! Thanks everyone for the help. It's nice to know if I need to drive at night, I can. But I think if they fail again, I will just exchange them for re-built. Yep, costs a little extra but I noticed the Little gear was worn and pretty much on both sides so turning 180* isn't going to work.
