Quick Fuse question
Old May 30, 2008 | 02:47 PM
autocolor's Avatar
autocolor
Default Quick Fuse question
Not sure if I have the correct / original fusebox in my 61 but I can find no pictures to tell one way or the other .
The box I have has 6 main fuse positions most of which are labled but unfortunately a couple of pieces of the outer frame are broken off .
From the top I have as listed below .
Tail ???? 35A
Spot Ant 15A
Back up Brake 10A
4A Radio WB Rad 7.5A
10A Heat Air Con 20A
Inst Ips ? ?A
I would be interested to know if this is the correct box and if not what the correct ratings are for the various usages , I have just fitted new side and tail lights and keep blowing the "tail" fuse but this originally had a 5amp fuse , this takes out all the side lights and brake lights but leaves the indicators working . What would be a safe value to run for side and brake lights ? 35A seems a bit high to me .
Cheers
Mike .
Old May 31, 2008 | 06:23 AM
autocolor's Avatar
autocolor
Quick update , I have fitted a 10A to the "tail" fuse slot and after a decent run it seems to be holding OK .
I would still like to hear your reccomendations for the tail fuse value and understand if I have the correct fuse block .
Mike .
Old Jun 1, 2008 | 04:28 PM
autocolor's Avatar
autocolor
Getting desperate
looked everywhere I can think of but still no description or pics of what my fuse box should look like , and I can find no reference to the various fuse ratings . Nearest I got was the box from CC but unfortunately the pic is out of focus so not much help , surely someone on the forum has the answers ?
TIA
Mike
Old Jun 1, 2008 | 04:43 PM
62Jeff's Avatar
62Jeff
This is the original fuse box from my 62, uploaded in LARGE size so you can see better. Tail is a 15 Amp fuse on mine, not 35 Amp as you noted in your first post....
Old Jun 1, 2008 | 05:35 PM
autocolor's Avatar
autocolor
Thanks for the pic , thats just great .
Could you please let me know what the letters are on the right side of the tail" fuse , and the letters on the bottom right .
Thanks again
Mike
Old Jun 1, 2008 | 05:48 PM
62Jeff's Avatar
62Jeff
Thanks again
Mike
To be clear, you are asking what words or letters are on the same line as Tail and Instr?
Old Jun 1, 2008 | 05:52 PM
autocolor's Avatar
autocolor
Yes , the word / letters on the right side of the "tail" fuse
, and also the word / letters on the bottom right side of the "instr" fuse .
Cheers
Mike .
Old Jun 1, 2008 | 06:18 PM
DZVette's Avatar
DZVette
Auto color,
Here's a shot of the fuse box from the new Lectric Limited harness for my 1960. Looks to be the same as Jeff's above.
DZ
Old Jun 2, 2008 | 03:35 AM
autocolor's Avatar
autocolor
Cheers guys
that answers all of my questions , the pics are ideal for future reference , now I can check that all of my fuses are of the correct value .
Once again the forum comes through , what would I do without all the excellent knowledge on this site ?
Thanks again
Mike
To Quick Fuse question
