Save the radiator or replace?
Old Jun 6, 2008 | 01:11 PM
Mark Snyder's Avatar
Mark Snyder
Default Save the radiator or replace?
I have an original '60 Corvette radiator that is hammered by the fan. Should I attempt to have it re-cored and save it or get a repro? The tanks are perfect. It is mangled where the fan and the radiator became one while the engine was running. I would prefer to reuse as many original parts as possible. With new one cost $1K i thouhgt I could spend some money to save this and be ahead.
Opinions on option and who can re-core?
Thanks!
Old Jun 6, 2008 | 01:15 PM
5thvet's Avatar
5thvet
I'm not sure if a 60 has an alluminum radiator but if so it cannot be re-cored. I'm sure a 60"s expert will help and verify.
Old Jun 6, 2008 | 01:35 PM
JohnZ's Avatar
JohnZ
Thanks!
Any competent radiator shop can re-core it using your original tanks; if originality is important to you, DeWitts has replacement '60 cores that are identical to the original. He also has an aluminum duplicate (A55M) of the original copper/brass radiator that looks identical when painted black, with about 35% more cooling capacity.
www.dewitts.com
Old Jun 6, 2008 | 01:49 PM
5thvet's Avatar
5thvet
www.dewitts.com
Mark,
There you go, I knew an expert would chime in
Don
Old Jun 6, 2008 | 01:56 PM
1COOL60's Avatar
1COOL60
From: Emporia, pay no attention to that man behind the curtain, KS
I assume you are talking about the lower-horsepower brass and copper radiator.
If you are wanting to stay as original as possible when re-coring, remember that the core was a stacked-plate design, not a tube-and-fin. Before I went with De Witts aluminum replacement, I had mine re-cored years ago. The shop I went to could not replace the core with a stacked-plate core, so I had them install a tube-and-fin core. It worked okay, but I would recommend the De Witts; much better cooling.
To Save the radiator or replace?
