Water pump failures
Old Jun 16, 2008 | 11:23 PM
Mossy66's Avatar
Mossy66
St. Jude Donor '14
Default Water pump failures
Why are my water pumps failing? I've had the car a year now and I need another water pump. This will be the fourth one. The first one failed after I'd owned the car for a month or two, and I thought nothing of it. I replaced it with a water pump from Pep Boys. It was a Bosch unit and it lasted about a week. I think it was junk from the get go. I returned it and got one from NAPA. That one failed today. (bearing sqauealing, or impeller rubbing the back side of pump, but still works)
The engine is a 327 350hp from a '67 corvette. It does not have the correct intake manifold. I am mentioning this because I read something in the archives after doing a search that the high hp cars had a bypass to prevent cavitation? The engine has extra pulleys so I installed a belt from crank to water pump in addition to the alternator belt. I do not believe the belts are too tight
The first and third water pumps failed immediatly after a couple of spirited runs through the gears near redline.
So what do you think, am I just unlucky with water pumps?
Gerry
Old Jun 16, 2008 | 11:30 PM
BarryK's Avatar
BarryK
you mentioned "extra pulleys". is the idler pulley installed?
Old Jun 17, 2008 | 01:40 AM
ghostrider20's Avatar
ghostrider20
The by-pass hose is not an issue. The heater acts as a by-pass circuit as well. Unless you have some sort of shut off. In that case, there is a small hole in the left boss for the circulation.
When running can you notice any wobble from the pulley?
Mark
Old Jun 17, 2008 | 05:56 AM
Bowtyeguy's Avatar
Bowtyeguy
Are the pulleys lined up? If they are cocked they will make the bearing in the pump go bad, but probably not in a day. It might if you gorilla tightened the belts and they are not aligned correct.
Old Jun 17, 2008 | 06:09 AM
Mossy66's Avatar
Mossy66
St. Jude Donor '14
No idler pulley. the belt just goes from crank to water pump.
Gerry
Old Jun 17, 2008 | 06:14 AM
Mossy66's Avatar
Mossy66
St. Jude Donor '14
Actually the alternator pulley is not quite lined up. It's ok in the fore-aft position, but not quite parallel.
I didn't notice any wobble. I'll check that again with the new pump.
Gerry
Old Jun 17, 2008 | 06:53 AM
ffas23's Avatar
ffas23
Doesn't surprise me any since most of the new replacement water pumps out there today are coming out of China whether it be sold by NAPA or anyone else. Funny though back in the early 70's I remember well before getting into the auto parts business replacing 3 Borg/Warner brand new water pumps in a row in my '67 Vert. The 3rd one held out but the first 2 leaked from the weep hole right from the get go and back then they were made in the USA.
Old Jun 17, 2008 | 07:12 AM
plaidside's Avatar
plaidside
I had a customer last week with a 79 Vette who replaced a couple of pumps before coming to me.
After questioning him I found he had an aftermarket fan clutch on the engine.
When I asked if he checked to see if the bushing was in place he said there was no bushing in the fan clutch.
Most after market fan clutches come with a bushing to reduce the pilot hole to 5/8 instead of the later 3/4". Early small blocks have the smaller pilot shaft.
Just something else to look for.
Old Jun 17, 2008 | 11:11 AM
JohnZ's Avatar
JohnZ
Exactly - If you have a mis-matched fan clutch vs. the pilot diameter on the water pump shaft with no precision bushing to center the back of the clutch on the shaft, that tiny off-center difference multiplied by the weight of the fan clutch will tear up the bearings and seals in a water pump almost immediately.
Old Jun 17, 2008 | 03:04 PM
MikeM's Avatar
MikeM
A clue would be that you get a good seat of the pants and hand massage from the engine vibrations coming through the steering column and the seat. If that's what's wrong, (and there is something wrong) I'm not suprised that you would have water pump problems. Ordinarily, even rebuilt pumps will last a long time if you don't overtighten the belts.
[QUOTE=JohnZ; that tiny off-center difference multiplied by the weight of the fan clutch will tear up the bearings and seals in a water pump almost immediately. [/QUOTE]
Old Jun 17, 2008 | 07:34 PM
Mossy66's Avatar
Mossy66
St. Jude Donor '14
A hand massage to the seat of my pants!?
No, the fan clutch is a replacement that came with a bushing to center it. I will double check when I re-assemble.
Thanks,
Gerry
Old Jun 17, 2008 | 07:45 PM
Deadrise's Avatar
Deadrise
Default Belt
Gerry,
I have a similar setup, one belt..
I want to add a second as a backup.. What was the size of the belt you used to go from the crank to the water pump//
Bill
Old Jun 17, 2008 | 09:24 PM
Allcoupedup's Avatar
Allcoupedup
I had the same problem. Went through two Carquest pumps that were blown out by runs to 6500 RPM. I had Arthur Gould build me one with a "heavy duty" (as he called it) bearing and I haven't had a problem since. Arthur advertises in NCRS and is a super nice, honest, and reputable guy. He specializes in Corvette water pumps.
I should have known I was installing junk from Carquest when the computer said it could also be used for truck applications.......
Your belt tension could also be too tight.
Brian
Old Jun 18, 2008 | 01:57 AM
mrg's Avatar
mrg
Weiand carries the 'Action-Plus' line of water pumps. The one I bought was aluminum and has a 3/4 inch impeller shaft. Nice beefy unit. .. The front of the impeller shaft is stepped down to a 5/8 inch pilot that will accept the earlier style fan clutch.
Old Jun 18, 2008 | 08:59 AM
Plasticman's Avatar
Plasticman
Originally Posted by Deadrise
Gerry,
Bill
Bill,
"Trial and error" is the belt size I found! Variations in crank and water pump pulley diameter will force you to try a variety of belts (unless someone has the exact same pulley combination, and can supply you with the belt they used).
Just take a rough measurement with an old cut belt (or even a tape measure), and ask an old school parts store to let you try belts around the size you measured. Putting the belt on is not difficult, once the fan and water pump pulley is removed. Just reinstall the water pump pulley with the new captured belt.
A caution to NOT tightening up the accessory belt too much. Remember that excessive belt tension, loads the crank snout upwards, and will damage both the crank snout journal and upper bearing half (besides trying to bend the crank). Ever remove the main bearings, and wonder why the upper front bearing half was worn? There is a limit as to too much tension.
Good luck,
Plasticman
Old Jun 18, 2008 | 01:09 PM
magicv8's Avatar
magicv8
My 66 sb engine has an A-C compressor for the first 7-8 years I owned it, It cracked the pump housing any time I power shifted with A-C running or revved to the limit. After 7 or 8 failures, I finally installed a 71 GM pump, much heavier duty, but required a TransAm A-C/alternator pulley and 3/4 inch fan adapter. That worked for 7 years.
A few of years ago I got a Stewart cast iron pump which has all the reinforcement webs in the casting that the 71 GM pumps do - along with the bigger bearings for the 3/4 shaft (like the gm 71 pumps) BUT the nose of the shaft is 5/8inch, so the stock fans, pulleys, and clutches for a 63-67 will fit.
I am very happy with the Stewart pump, and I was able to reinstall the factory pulley.
Old Jun 18, 2008 | 02:29 PM
Barry's70LT1's Avatar
Barry's70LT1
I have the same water pump on my '70 as most 283/327 engines. (Small bearing pump)
Many years ago (at 6500 + rpm) the front bearing seized and twisted off the shaft.
Fortunately it only took out the shroud and rad.
I had no success with any of the rebuilt pumps. A few trips to 6,500 rpm and the pumps
were toast.
I finally went with a Stewart Aluminum pump ( 3/4 inch impeller shaft/5/8 inch pilot) and
it has been working great for about 13 years now. (Not NCRS correct, however the fan
has not gone thru the rad lately).
Thanks, Barry
To Water pump failures
Old Jun 18, 2008 | 04:53 PM
Mossy66's Avatar
Mossy66
St. Jude Donor '14
Default I think I found it
While putting the water pump on last night I paid close attention to the centering bushing in the fan clutch. I saw that it wasn't long enough to be flush with the mating surface on the pulley. It was recessed a good 1/4" or more. And it was a loose fit, it would drop out if you tipped it upside down. Then I looked at the water pump shaft. It only protruded past the pulley by about 1/8". So if I just threw the fan clutch on without paying attention, that bushing would be recessed too far back to come into play. I dropped a couple of flat washers behind the bushing to bring it flush, and I think I'm good to go!
I don't know if this was the problem with the other pumps because they are gone and I can't look at them, but it would have been a problem with this one if I hadn't paid attention.
So I would like to thank you guys for helping me out with this one.
Gerry
Old Jun 18, 2008 | 04:59 PM
Mossy66's Avatar
Mossy66
St. Jude Donor '14
Gerry,
Bill
Bill,
Mine is a NAPA Premium XL 25-7550
The engine is a '67 327-350Hp that had air and power steering
the water pump pulley has 2 grooves
Edit: Thats 25-7350. I was looking at the wrong belt
Crank has two grooves and a third pulley bolted to the front of that.
Hope that helps.
Gerry
Old Jun 18, 2008 | 05:12 PM
Scott Marzahl's Avatar
Scott Marzahl
I'd at least run a Delco water pump and new Delco fan clutch, 3916141. The aftermarket clutches do not seem to hold up that well, kind of get what you pay for with fan clutches.
