I have a Flarestat 105 Hazard Switch but it does not have the correct type of plugs wired to it. I have used an old plug from my old dash wiring harness for one end.
However, I need the two plugs from the indicator assembly on the steering column for the other end.
If someone has replaced their indicator assembly perhaps I could purchase the old plugs or perhaps you my know of a supplier in the US.
I have emailed Lectric Limited asking to buy the plugs but no answer as yet.
Thanks,
Gary C,
Perth Australia
Both Lectric Limited & M+H Electric Websites say they will not sell separate connectors and there are no old Chevs in the junk yards in Perth.
So it looks like my only option is to buy a new indicator assembly and take the connectors off.
Thanks anyway,
Gary C
Perth, Australia
I would suggest ebay - any one from a 64-66 pickup. Impala or Chevelle should fit - model number is 105-Y79. I just bought a Chevelle model for $70 with all wires and plugs and it works fine. You can use them as is or hackk the wires off. The hazard flasher was dealer installed through 1965. Earlier ***** were fluted with 3 bowties on them and the 64-66 ***** were smooth. Good luck
