Steering Column
Old Jul 7, 2008 | 02:38 PM
mredi1's Avatar
mredi1
Default Steering Column
Can anyone decode these two part numbers on a 1964 - 1966 steering column - 3828382 and 3845728 . Thanks Tim
Old Jul 8, 2008 | 07:14 PM
mredi1's Avatar
mredi1
Trying to confirm what this steering column is out of if possible by the part numbers on the column. Thanks Tim
Old Jul 9, 2008 | 09:51 AM
mredi1's Avatar
mredi1
ttt
Old Jul 9, 2008 | 10:31 AM
dkleather's Avatar
dkleather
2016 C2 of the Year Finalist
Tim,
Part #3828382 is listed in my 1964 AIM as being the steering wheel hub. Couldn't find a listing for the other number. Dave
Old Jul 9, 2008 | 12:59 PM
mredi1's Avatar
mredi1
Originally Posted by dkleather
Tim,
Dave, Thanks, that means the steering column is most likely out of a 1964 model. Just was trying to confirm by the part number what year it may be out of. Let me check my 65 AIM to see if it is listed for a 65 as well. Thanks again, Tim
Old Jul 9, 2008 | 01:14 PM
dkleather's Avatar
dkleather
Tim, What did you get the part number 3845728 off of. I might be of more help if I knew and could look for a specific part in the "64 AIM. Dave
Old Jul 9, 2008 | 01:29 PM
mredi1's Avatar
mredi1
The numbers came from the guy who has the steering column, they are somewhere on the column. I was just trying to verify the year it came out of, as it needs some work. If the price is right and it is out of a 64-66 I might be interested in getting it. I have a 65 so want to make sure it would work. I will see if I can find out specifrically where the numbers are on the steering column. Have to go get my AIM out of the garage.
Tim
Old Jul 9, 2008 | 08:46 PM
dkleather's Avatar
dkleather
Tim, FYI..You probably already know this but if you're also buying the steering shaft make sure it's not worn at the bottom column bearing area. You can buy replacement shafts for about $100 but I know I wouldn't pay as much for a column that needed a shaft. I've seen some nearly worn to half thickness due to a bad bearing.
Old Jul 10, 2008 | 07:28 AM
mredi1's Avatar
mredi1
Yes, mine has some wear, that is why I'm interested in getting a replacement, rebuilding it and then swap it out. This way I can take my time and still be able to go for a drive. Tim
To Steering Column
