Dash Pad Install
The new pads are going to require some pressure to line the holes up for the clips, especially the drivers side. Does anyone recommend a sequence for installing the clips so I don't walk myself into a situation where I cannot get the last few sets of holes to line up? (I could not find anything in the archives.)
The note: I'd noticed in the archives that many of you recommended pulling the entire dash shell from the car, especially to facilitate removing the clips in the "center stack" area. I found instead that by cutting away the outer skin on the old pads, that the back side of the clip was accessible. It was then just a squeeze of the pliers and the clips fell out. (Of course the old pad is trash when you're done!) I'll post a pic if anyone is interested.
Harry
