I would like to replace the shift boot on my 1960 Roadster but can't seem to see how to do it. The old shift boot edging goes under a plate that also houses the ash tray. There are 2 screws on the plate but they are very short and appear to only hold on the shift pattern. Can anyone tell me what I have to do to replace my torn boot?
1) Remove the 2 screws that hold the shift pattern
2) Remove shift pattern
3) Then you'll find one or two screws that hold the shift plate to the transmission tunnel. Remove the screws
4) Shift plate should lift out
Note that some repro shift boots have a metal edge bonded to the rubber, some don't (or didn't 20 years ago). The ones without the metal edge bonded to the rubber would tend to pull out of the lower left corner of the shift plate on 3rd gear shifts.
The information above, provided by Jeff, is probably about the most complete and accurate information that you are going to get!
I've got the Paragon boot. It's pretty good, and an improvement over the original.
Don't overstress the 2 nuts that hold the 2 screws that hold the shift plate. They attach somehow to the underneath of the fiberglass tunnel floor. If you break them, you'll have the opportunity to go in there and hold the nut while your helper does the screw and driver from above. You'll see that they're sorta flimsy.
YEP!!!
Sooooooooooooo, I got a strip of fairly thick stainless sheet metal, drilled holes to match the plate, tapped holes to match the screw threads (seems like 10-32 threads) and pop riveted the stainless to the underside of the fiberglass. Can't be seen, unless you crawl under the car with a flashlight with the intention of looking for it. Only a fool (or NCRS judge) would do that!
