Replace 67 Hand Brake Question.
Old Jul 31, 2008 | 01:09 PM
1966STER's Avatar
1966STER
Default Replace 67 Hand Brake Question.
I would like to replace my hand brake assembly ---- I have removed the hand brake console and it it looks like there are only (4) bolts holding this in place which looks fairly simple. --- What I'm not familar with, is how the cable attaches to the assembly and can it be accomplished from inside the car (from the top) or will I have to get underneath the car?
Thank you.
Old Jul 31, 2008 | 01:17 PM
JohnZ's Avatar
JohnZ
The detailed step-by-step procedure is on pages 5-13 and 5-14 in the 1967 Chassis Service Manual; you'll need to get under the car to remove the return spring and the rear nut on the cable stud at the equalizer first.
