Solid State Regulator Question.....VR715
Old Aug 18, 2008 | 02:44 PM
gask99's Avatar
gask99
Default Solid State Regulator Question.....VR715
Do you still use the capacitor that is mounted to the side of the original regulator?
Old Aug 18, 2008 | 03:04 PM
LB66383's Avatar
LB66383
I'm not sure if it's necessary or not, but I've always put it back on. There is a tab on the back for it to plug into.
Old Aug 18, 2008 | 03:14 PM
gask99's Avatar
gask99
OK, Thanks
Old Aug 18, 2008 | 05:28 PM
gask99's Avatar
gask99
Default 66 Convertible
$15.00 at NAPA. Can't beat the price. Works great.
Tom
Old Aug 18, 2008 | 06:20 PM
ghostrider20's Avatar
ghostrider20
If it has a chrome/stainless cover, you can use a scotch brite pad to etch it and paint it semi flat black and it will look real close to the original one.
Mark
Old Aug 18, 2008 | 06:56 PM
67vetteal's Avatar
67vetteal
I installed the VR715 yesterday. I've always had an Amp Meter that would show a discharge at all times. Meter hardly moved to show current direction. After installing the VR715 I still show the discharge when the car runs but see much more activity as current use is detected. Al W.
Old Aug 18, 2008 | 07:44 PM
gask99's Avatar
gask99
It came with a black cover that seems to be glued on. Will try to put original cover on it in a few days.
Old Aug 19, 2008 | 03:30 PM
LB66383's Avatar
LB66383
I believe that cover is riveted on. People here have drilled out the rivets, then used screws in those holes to mount the original Delco cover so it looks like the stock mechanical regulator.
To Solid State Regulator Question.....VR715
