Electrical taping techniques
Old Aug 26, 2008 | 11:13 AM
Frankie the Fink's Avatar
Frankie the Fink
Army
Default Electrical taping techniques
I don't see this talked about here - I've been retaping some of my dash harness and started wondering about the best electrician's tape to use and best method to apply it. Seems no matter what I do it starts unraveling after a while and leaves a sticky mess all over the wiring.
I try to keep tension on it and stretch it as I apply it corkscrew wise and double wrap the last loop....still seems to come loose later though.
What have others done that worked better ?
Old Aug 26, 2008 | 11:29 AM
jim lockwood's Avatar
jim lockwood
C2 of Year Finalist (track prepared) 2019
You don't want to use electrician's tape. The original black harness tape used on wiring harnesses has no adhesive. It was just wrapped around the bundle of wires and then tied off at one end.
You can buy rolls of harness tape from Lectric Limited, their part number: PM674-005S
Jim
Old Aug 26, 2008 | 11:38 AM
Frankie the Fink
Army
Jim
I actually bought a roll of that and started using it this week - how do you 'tie it off' at one end though ? (We used to use waxed string when I did it back in my F-14 Tomcat avionics days..)
Old Aug 26, 2008 | 12:59 PM
Pop Chevy's Avatar
Pop Chevy
2021 C1 of the Year Finalist - Modified
I use tiny wire ties.
Old Aug 26, 2008 | 01:51 PM
kenmo's Avatar
kenmo
I've experienced this as well.... So I'm watching this thread with interest...
Old Aug 26, 2008 | 02:02 PM
Donny Brass's Avatar
Donny Brass
2017 C2 of the Year Finalist
it does not matter how you wrap the tape, she will wiggle out.
now duct tape will hold her in place........
Old Aug 26, 2008 | 02:19 PM
jim lockwood
Waxed string? You mean old fashioned lacing cord? I've wrapped many a harness with that stuff. I've still got a roll.
Tieing the end of the harness tape is about as simple as it sounds. When you get to the end of the harness with your wrap, wrap a few extra turns of tape, pulling them all tight as you go. While holding most of the last several turns of harness tape with one hand, loosen the the last couple of turns just enough to thread the end of the tape underneath and start making a knot. Pull tight.
That's the technique I use, but experiment to develop your own technique. Since harness tape has no adhesive, you can always unwrap it and try again.
Jim
Old Aug 26, 2008 | 02:28 PM
wmf62's Avatar
wmf62
St. Jude Donor '07
Frank
this is what i used to wrap all the harnesses we made when doing all my mods; i got it at Lowes. seems to be, as the name implies, super tape...
i have always done the wrapping by lapping half over the preceding wrap and then when i get to the end do several over-wraps and stretch the tape tight until it snaps. John prefers to do the ends by several over -wraps of normal tightness and then instead of stretching the tape until it snaps, snip the tape and just stick it in place. either way, so far, has stayed tight; even with the heat of the engine compartment.
Bill
Old Aug 26, 2008 | 03:17 PM
JohnZ's Avatar
JohnZ
That's exactly how it was done at Packard Electric.
Old Aug 26, 2008 | 03:20 PM
BarryK's Avatar
BarryK
I HATE black electrical tape in cars. It never stays wound, it will unravel and leave a sticky mess. This goes back years from when i was in the car audio industry.
If I need to splice wires I always solder and use heat shrink over the connection. Nice, neat, professional, and it no messy stickiness from electricians tape. If I need to splice several wires in the same harness I stagger the solder splices so they are not all in the same place otherwise you get a big lump when wrapping the harness back up.
If I need to wrap wires in a harness I also use the black harness tape with no adhesive like Jim mentioned. It's neat, no stickiness, stays wound together, and you can unwrap it and redo it when needed.
When I got my '78 it had a non-working aftermarket alarm system in it that I had to remove. Everything was connected with butt connectors (I hate those too - that's just a connection waiting to fail!) and TONS of electricians tape. H*ll, half the connections weren't even butt connected together, just bare wires twisted together and wrapped in electricians tape. What a mess! The wires and my hands were covered in black sticky crap all over from the tape. Man, I was cussing Bubba the alarm installer on that deal.
Old Aug 26, 2008 | 03:21 PM
Allcoupedup's Avatar
Allcoupedup
Originally Posted by wmf62
Frank
Bill
I used this stuff too and it worked great.
Old Aug 26, 2008 | 04:13 PM
Frankie the Fink
Army
Jim
Yeah lacing cord & I too have wrapped many an aircraft harness from P-2 WW-II aircraft to F-4s, A-6s & F-14s. I had a roll of that as well as a large spool of stainless steel safety wire which I lost or gave away over the years and occasionally cuss myself for not having it around !
Old Aug 26, 2008 | 05:01 PM
Allcoupedup
They still used the lacing cord in telecommunications offices to dress cables. I used to work in engineering for a telecom equipment manufacturer and rolls of it were all over the place. My favorite use is to bundle branches for curbside pickup!
brian
Old Aug 26, 2008 | 06:15 PM
cbernhardt's Avatar
cbernhardt
C1 of Year Finalist (track prepared) 2019
I bought some of this stuff at from a vendor at Carlisle. It looks interesting, if it performs as advertised. It has no "stickum" on it and sticks only to itself. Only drawback for wire wrapping would be that when it bonds to itself it is more or less permanent depending on the pressure of the wrap, so it may have to be cut off to remove it. Supposed to be used mainly for patching leaks in hoses, but I bought it with the intention of using it as wire wrap.
Old Aug 26, 2008 | 06:59 PM
Frankie the Fink
Army
I believe that is what we used to call in avionics "Vulcanized" tape..its really good stuff for wrapping aircraft cables and does NOT come loose..its a bit thick and ugly for use on classic car harnesses though....and yes you have to cut it off once its properly applied.
To Electrical taping techniques
