Roll bar??
Old Oct 7, 2008 | 05:47 PM
Corbrastang's Avatar
Corbrastang
Default Roll bar??
Has anybody added a roll bar to their midyear convertible or coupe? I know this is considered a sin, but i just dont feel safe in this car anymore. If i can find a roll bar that will still allow me to use the hardtop then i might purchase one and add 4 point harnesses.
Thanks and please done flame me for asking-i am really just curious
Old Oct 7, 2008 | 08:04 PM
Hitch's Avatar
Hitch
Why all of a sudden the aversion to old cars? They are all death traps especially Corvettes. No side beams for side impact lap belts... I'm sure you can add a roll bar and some of them have looked cool that I've seen. I'm just not sure you can add one and still retain the soft top.
Dave
Old Oct 7, 2008 | 08:16 PM
roger newman's Avatar
roger newman
I have a removeable roll bar in my vintage race car. I like the stiffness the roll bar gives and the added safety.
Old Oct 7, 2008 | 09:02 PM
Vogie's Avatar
Vogie
If racing rules are a consideration, you might want to check the minimum above the head distance and position of the cross bar that the shoulder harnesses mount to in the applicable rule book. Good luck.
Old Oct 7, 2008 | 09:11 PM
427Hotrod's Avatar
427Hotrod
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
I had a custom one built for mine. No one makes one that allows the soft top to operate. I had it made from moly and it is a bolt in which makes it removable. I still had to notch the deck lid. We tried everyway we could think of not to do it....but finally gave in.
I also added removable swing out side bars. When all put together it really stiffens the car a lot.
When it was all done it was powdercoated to keep it shiny.
Plus I don't get thrown out of the tracks quite as often these days!
JIM
Old Oct 7, 2008 | 11:13 PM
KENS78SILVERANNIV's Avatar
KENS78SILVERANNIV
When I started on the Forum years ago... it was O.K. to ask any question related to these cars. Don't be intimidated by some of the purists who post here. If you want to put a roll-bar in your ride...Go for it. If you want to leave it bone stock... more power to you.
Good Luck in your search.
Old Oct 8, 2008 | 01:49 AM
sub006's Avatar
sub006
If you don't need to pass tech inspection for racing (just want added safety for street use):
A CHROME rollbar, especially a narrow single hoop for driver's seat only, is a classy vintage touch. Looks better IMO with the C2's other trim than race-style flat black or padded vinyl.
Old Oct 8, 2008 | 07:07 AM
78Vette-SA's Avatar
78Vette-SA
That's a good question and something I was thinking about. Would love to see pics of convertibles with a roll bar in them (with the top down).
I'd gladly do some welding and cutting if necessary if there was a decent looking setup. And of course if there was no problem with the top up and down.
Old Oct 8, 2008 | 09:35 PM
Corbrastang
Im not sure why i am scared all of a sudden. I guess i got old, or i am getting there.
Anyway, i have a hardtop for the car now so i dont need the rollbar to be functional with the softop. A bolt in option would be nice. However, that would mean that the body would need to come back off. Im just thinking about it and i would love to see some pictures of coupes and coonvertibles with all types of roll bars.
Old Oct 9, 2008 | 07:52 PM
Pop Chevy's Avatar
Pop Chevy
2021 C1 of the Year Finalist - Modified
I bent one for my Coupe out of 1 5/8 DOM. When I stripped the old carpet out I found holes in the floor for one. The holes were patched with old shingles, so I decided to put a bar back in. I'll try to get ya a pic of it but the cars not finished yet.
Pops
Old Oct 9, 2008 | 10:50 PM
Shurshot's Avatar
Shurshot
When I get around to lifting the body to do some frame upgrading I plan to add a roll bar and a good harness would then be a given. Although I like the harness for keeping me in the right place with stock seats adding the roll bar would be more for added stiffness and getting by the track inspectors then fears of ever needing it
Doug
Old Oct 9, 2008 | 11:41 PM
63Corvette's Avatar
63Corvette
Of course I have a roll bar. Since you must have front to rear brace, I would recommend a full width bar with twin rear supports. that obviates the need for a front support which renders your passenger seat usless. I don't have a diagonal brace, but most race sanctioning organizations require one. It is good theory, but restricts access to your rear area.
Old Nov 8, 2008 | 11:46 AM
Klamath Stoogie's Avatar
Klamath Stoogie
JIM
Hey Jim, awesome 'vette. Do you have any pics that show the roll bar up close?
Old Nov 8, 2008 | 12:54 PM
Mark_Milner's Avatar
Mark_Milner
Then don't do the main mistake most do. Do not leave it bare. Pad it.
In a wreck, your head will hit a 1.5 to 2.0 inch piece of pipe and you or your beneficiaries will regret that lack of padding for a long time.
A bare chrome bar may look cool, but so does play Russian roulette.
Old Nov 8, 2008 | 12:58 PM
Mark_Milner
Before you put the body on, weld that plate for the main hoop to the frame. Your bolts are in shear and could fail depending on how you go upside down.
Bolts are tension components, not shear. While odds are you'd still survive and the bolts don't fail, you can guarantee they don't if the plate is welded.
Same thing for the retaining bolt on the hoop. Be sure the hoop bottoms in the tube, and doesn't rest on the bolt.
Old Nov 14, 2008 | 09:44 PM
FastEddy's Avatar
FastEddy
Corvette = low center of gravity = hard to roll = unless you go off road - if you do, a single type roll bar won't do much good against soft ground, trees, or......cattle.
I hit 3 different cars, and spun 3 full revolutions, and somehow managed NOT to hit my head on my "roll" bar......that was probably my closest threat........for legal reasons I won't mention anything about the speed.
Not a scratch on me.
Racing belts kept me in the car.
Small fire extinquisher put out the fire.
Don't worry about it, unless it's a full cage, it ain't worth the trouble most likely............
Old Nov 14, 2008 | 09:49 PM
FastEddy's Avatar
FastEddy
But since your asking, this was a nice job on one - was recessed into the rear deck to allow seat to go all the way back - cleared soft top......
To Roll bar??
Old Nov 15, 2008 | 06:03 AM
obx2323's Avatar
obx2323
Originally Posted by fasteddy
corvette = low center of gravity = hard to roll = unless you go off road - if you do, a single type roll bar won't do much good against soft ground, trees, or......cattle.
I hit 3 different cars, and spun 3 full revolutions, and somehow managed not to hit my head on my "roll" bar......that was probably my closest threat........for legal reasons i won't mention anything about the speed.
ouch....!!!!!!
Old Nov 15, 2008 | 09:55 AM
roger newman
I welded all the plates prior to powder coating.
Old Nov 15, 2008 | 10:27 AM
Tintin's Avatar
Tintin
Cartoon Character
Autopower makes a rollbar that bolts in to the car:
Corvette Convertible 63 - 83 71390 C,D,J,L 70390 C,D,G,J,L 70390C
I have used their stuff in at least 20 showroom stock racers over trhe years and they always fit and are really strong (ask me how I know..)
Here is their web address:
http://www.autopowerindustries.com/
