C2 Trip Meter Question
Inside the wheels on the trip odometer is a series of trip wheels, if they bind up inside the wheels this would cause the problem you have. My advice is to remove this speedometer as soon as possible. If the trip odometer is locking up, it can cause the trip drive gear mentioned above to strip out, strip out the odometer drive gear and/or damage other internal parts.
Before the odometers and trip odometers were available in reproduction we used to take them apart to fix the internal parts. However, it’s to time consuming to do this considering the cost of the reproduction odometer.
If you remove the speedo, replacing the trip odometer is a snap. We have these in stock and I really think simply replacing it will solve your problem. http://willcoxcorvette.com/product_i...ducts_id=18727
If you remove it, give my sales staff a call and they can walk you through how to get this out! I really don’t think you need to send this unit anywhere. You can test the trip in your hand once it is removed form the car by holding the lock levers and rotating them by hand. If they bind up, you’ve found your problem. If they don’t then you will need to send this to someone for a repair.
If you have any questions, email me at Willcox@Willcoxcorvette.com
Willcox Inc.
Willcox Inc.
I've tried this with my rebuilt cluster and it didn't reset all the way to zero and seemed to hang up. I thought I broke it but the trip odometer still turns. I guess I'll check the cable routing.
