C2 Trip Meter Question
jack
Now back to the post, does this mean I have to pull the speedometer or the whole dash? Do you have any recommendations on where to send for a rebuild? Thanks!
Corvette Specialties of Maryland
Joe Ray Parts Co.
D&M Restorations
Corvette Instruments
When you get to our home page, click on the Restoration tab, then select 63-67 see details.
I will be happy to extend a discount to you as a forum member of 10% through the end of 2008 if you mention this when you send in your work. Other forum members are welcome to join in and we will be happy to extend the same benefit on our restoration services. Please be sure to mention this when you send in your parts. We provide a very specific order form that will enable you to get all of your information together for our services. The form is on our home page, upper right www.csofmd.com
I can also be reached by phone if this is not clear.
The reset cable is something I will look at though. One thing I have tried was to remove the **** to insert a tiny rubber filler and then reinstalled it with a little cement so that I culd be sure it wasn't spinning on the shaft. My hope was to gain more travel as I depressed the ****. That had no effect.
I can use the old tach drive distributor fix as another way to describe this situation.
How many times have you either tried, or seen another person try to replace only the small tach drive gear when it was stripped? Real easy to do it, don't even need to remove the distributor right?
Wrong, in a short time, that real nice new gear will try to mesh with the old stripped main shaft and bingo, you ruined another small gear. Now it is evident that BOTH gears need to be replaced. Remember when the speedo is properly rebuilt, it should last many thousands of miles, I do mean properly! Often the old odometers look ok cosmetically, but are just too tight and in no time, the gears will strip again.
Haven't you ever wondered why so many Corvettes have betrween 40,000 and 60,000 miles? Oh well I have rambled enough.
Will replacing the second worm with a correct steel worm (see below) solve the problem, as long as the other parts are in good shape?
I found a paper on the Willcox Chevy website (http://willcoxcorvette.com/instructi...suggestion.pdf) that says (in part):
"The second worm gear will be metal if original and plastic if a replacement. The chance's are it is a metal gear unless someone has already been inside and replaced it. When the brass bushing wears out in the back of the head it misaligns this gear to the second worm and wears them both out. You can replace the second worm gear and it might last a little while, but it will probably just eat it right up again." (page 3, after "exploded" diagram page).
From an archive search, I found this post by Forum member gaugetech (http://forums.corvetteforum.com/show...hp?t=2066149):
Also, here is a picture of gear B. Old one on top. As you can see it has worn so bad that it no no longer functions.
And here is a close up of C. Still in good shape. I may re-use this gear as the replacement is plastic.
Also, I assume that if you replace A and B gears, you will need to get the speedo head re-calibrated??
B: is your second worm this is the one that always should be steel not plastic.
C : is your third worm gear is should be steel as well
GM used steel worms because it is the most durable not because it was the cheepest it was done for a reason and to get the most use out of your speedometer you should use steel. Plastic will not last.................................... ..............
QUESTION:
If we replace all of the old worm gears with new steel ones, will that solve the problem?
Second question, by replacing magnet, (or first worm), second and third worms with new steel pieces, it will not make the problem disappear. The bronze bushing that is pressed into the main frame must be correctly sized to maintain alignment. In addition, the 2 thrust washers must be installed, and the flare on the magnet must be done properly to maintain the proper thrust or end play. If all of these are done properly, we then have a speedometer that should be no better then it was new! (as long as the odometers are not too tight!!) And it will still probably fail between 40,000 and 60,000 miles!!
Even when using a square headed screwdriver to move the wheel, it still takes a pretty good push to engage the gears. I would suggest that some aren't getting enough travel in the cable.
P.S. Never try to reset the number wheel while the car is in motion.
