Clutch Problems
Old Nov 12, 2008 | 10:37 AM
kyosho's Avatar
kyosho
Originally Posted by JohnZ
Paragon carries the same LuK clutch kit Jerry (gjfeng) put in his car, or an auto parts store should be able to order it for you from their sources, or you can get it from www.dialaclutch.com . The '67 Chevy Chassis Service Manual has the detailed procedure; be sure and have your flywheel resurfaced, and replace the pilot bushing.
Can you reccomend a shop in the area to have the flywheel resurfaced?
I live near you so something in northern Macomb County, etc.
Old Nov 12, 2008 | 12:39 PM
JohnZ's Avatar
JohnZ
Just about any good auto parts store can send it out for you, or you can try Heads-Up Racing in Mt. Clemens, (586) 461-0099.
Old Nov 12, 2008 | 12:43 PM
kyosho's Avatar
kyosho
Thanks.
Old Nov 21, 2008 | 03:13 PM
kyosho's Avatar
kyosho
Would this be the correct item:
http://www.corvette-paragon.com/p-35...-assembly.aspx
Paragon Number: 1568K
Includes Clutch plate, disc, throwout bearing assembly and pilot bearing. 1963-71 w/327 & 350,(10 3/8") 1966-69 w/427 (10 3/8")
This plus getting my flywheel resurfaced should be everything, right?
Comes with pilot bushing and throw out bearing.
Old Nov 21, 2008 | 04:09 PM
JohnZ's Avatar
JohnZ
Yup, that'll take care of what you need.
Old Nov 21, 2008 | 05:15 PM
gjfeng's Avatar
gjfeng
That looks like the same clutch kit I put in my 67 SB.
While you are there, you might take a look at the clutch linkage for any worn or deteriorated parts. You might anticipate replacing the clutch boot, anti-rattle springs, clips and other small parts for cosmetic or operational reasons while you are doing the clutch.
Just a thought
Old Nov 22, 2008 | 09:32 AM
kyosho's Avatar
kyosho
Thanks to both of you. Scott
Old Nov 22, 2008 | 08:16 PM
magicv8's Avatar
magicv8
Originally Posted by redred65cpe
21 minutes and a bump? Your thread is more important than anybody else's for what reason?
larry
my aren't we touchy?
