1961 engine code
Old Nov 20, 2008 | 12:26 PM
jcrawfo1's Avatar
jcrawfo1
8th Gear
Default 1961 engine code
A friend of mine who has become disable has a 1961 corvette with 55,000 original miles on it. I am helping him to get the car ready to sell and we are trying to id the number on the 283 engine to make sure it is original. The number on the right front of the engine is FIIOIEB and right below that number is 1004. Normally the numbers are in line from what we have seen. It has the chrome air cleaner and aluminum valve covers with a holly carb on it. My friend has had the car since 1975 when he bought it from the second owner. Any help would be appreciated.
Jim and Ken
Old Nov 20, 2008 | 12:49 PM
Donald #31176's Avatar
Donald #31176
Depending on the DOB the casting # on the block should be either 3756519 or late DOB 3789935. This #s is found on the rear flange driver side . The engine pad code EB is NOT a Corvette code. Should start with C or D depending on trans. Also an original Corvette engine for 61 would have a 6 digit VIN derivative on the left side on the engine pad.
Old Nov 20, 2008 | 01:51 PM
jcrawfo1's Avatar
jcrawfo1
8th Gear
thanks I'll check the DOD #, IS THIS NUMBER ON THE BLOCK OR THE HEAD ON THE REAR FLANGE?
ALL THE ENGINE PAD CODES THAT WE CHECKED HAD THE NUMBER ON THE LEFT SIDE OF THE FIIOIIEB NUMBER.
BUT THIS ENGINE DIDN'T.
COULD IT BE AN AFTER MARKET OR REPLACED ENGINE FROM THE FACTORY?
Old Nov 20, 2008 | 04:35 PM
JohnZ's Avatar
JohnZ
The block CASTING NUMBER is on the rear flange of the block, where the bellhousing bolts up, on the driver's side. The block CASTING DATE is on the same flange, on the passenger side, about 5" outboard of the distributor.
With those two numbers/codes, we can tell you where the engine came from - the ""EB" suffix was used on several different applications from '55-'67.
Old Nov 21, 2008 | 07:11 AM
jcrawfo1's Avatar
jcrawfo1
8th Gear
thanks John, for the help
Old Nov 21, 2008 | 07:30 AM
jcrawfo1's Avatar
jcrawfo1
8th Gear
also John was the EB code used on a 283 and the 327.
Old Nov 21, 2008 | 08:02 AM
john neas's Avatar
john neas
EB thru 1961
57 Pass 270 HP
58-61 Pass Turboglide& 4bbl
Regards
Old Nov 21, 2008 | 03:21 PM
JohnZ's Avatar
JohnZ
Originally Posted by john neas
EB thru 1961
57 Pass 270 HP
Regards
Also used for '65-'67 327 4-barrels in Chevelle/El Camino.
Old Nov 24, 2008 | 09:10 AM
jcrawfo1's Avatar
jcrawfo1
8th Gear
thanks John
Old Nov 24, 2008 | 09:18 AM
jcrawfo1's Avatar
jcrawfo1
8th Gear
thanks John
I was able to get the rest of the numbers you told me about and here they are.
The rear driver side number was:3737379
and the passenger side number was: J307
I think the 3737379 number ran from 1957 thru 1959 not sure on the J307.
The engine code is FIIO1EB which is Nov. 01 I think, but this number had the 1004 underneath it on the pad.
Old Nov 24, 2008 | 11:33 AM
JohnZ's Avatar
JohnZ
thanks John
No such number. Check it again - sure it isn't 3737739?
Old Nov 25, 2008 | 07:11 AM
jcrawfo1's Avatar
jcrawfo1
8th Gear
maybe it is, I'll have to check the number again ......
Old Nov 25, 2008 | 08:28 AM
zadspal's Avatar
zadspal
I think what you have is a late 57-58 block from a passenger car. the "E" suffix was used on corvettes in 57 but that was changed for 58 and the "B" isn't found in my NCRS Corvette Specifications Guide. The casting number used for 57 Corvettes is 3731548 and the casting number from your block would fit the 58 Corvette 3737739 This number was also seen in the "very" early 59 Corvette. I understand this probably don't help much with your friends situation but it's good info.
Old Nov 25, 2008 | 09:18 AM
zadspal's Avatar
zadspal
I would also like to add. This engine wouldn't have been a replacement from GM or the dealer. This block was cast and built years before your friends car was built. The time gap is too great for something like this to be reasonable. I would rather think that this engine was replaced later in the cars life by a reputable person with the original VIN stamped on the pad. Check the VIN along with the additional numbers that are stamped on the front pad (1004)and see if they match. If this is the last 4 digi's of your VIN number your car is an early production 61 and would have originally had a block casting number 3756519. In late 61 (around mid June) the casting numbers changed to 3789935.
IMHO, I don't think your friend has the correct block for his car. However! this block being a 3737739 (used in Corvettes) does have value to it and could be used as a barter for the correct one if you can locate one that your friend needs. One last note to remember! The correct block for this car would also be a "Flint" block with the "F" not a "T".
Good Luck!
ZADSPAL
Old Nov 26, 2008 | 07:23 AM
jcrawfo1's Avatar
jcrawfo1
8th Gear
Good Luck!
ZADSPAL
Thanks a lot, I think this answers all our questions on the 61. I really appreciate all the work that everbody has put in to help me answer these questions. This is truly a great source of information.
I will definately recommend this forum to anyone that might need it.
thanks again
Jim and Ken
To 1961 engine code
