where are the connectors shown on my 1964 wiring schematic?
Hi guys,
I'm pretty much through studying my 1964 wiring schematics (courtesy of papawana) and have just a couple of questions.
On page 3WD-104 there are two 8 pin blocks depicted near the top of the schematic. I assume this is the two sides of a connector. If my assumption is correct, then where is the connector and which pins connect together? Let's number the 8 points in the connector for reference. pin 1 will be top left and pin 8 will be bottom right. 1-4 on top, 5-8 on bottom. Using the same numbering convention for the 8 pins shown next to it, does 1 connect to 1 or what? If I had to guess, I'd say they mate actually as pin 1 on left connector to pin 4 on right connector and 5 to 8, etc, as if you folded the page in half (or mirror them)? Just guessing based on the wire colors and tracing connections as if they were made in this manner seems to be correct.
The same questions go for the four 8 pin blocks shown on page 3WD-105.
So all together, I suppose there are three 8 pin connectors somewhere in the car according to this schematic?
I don't know what 3WD-104 is, not owning any of Papawana's diagrams, but there are several connectors:
Engine Harness - Has a rectangle connector, connects to the fuse panel at the firewall, also called a bulk-head connector
Forward lamp harness - Has a rectangle connector, connects to the fuse panel at the firewall, also called a bulk-head connector. This connector and the one for the engine harness, are side by side, clear plastic connectors (covered in black wrap).
Rear harness - Also a rectangle connector, connects to the main dash harness up above the left kick panel, and is clipped to the "z-bar" support behind the instrument cluster. It is black plastic.
Some wiring diagrams show the main fuse panel as 2 sets of pin connectors, instead of representing it as one big square panel with 2 sets of connectors within it.
Perhaps you are seeing something like that?
Yeah, thanks. I think that will cover it.. let you know after Saturday..
which of the side by side firewall connectors is headlights and which is engine harness?
(I have no forward harnesses in my car anymore - have to rewire as I work through my LS2 install).
However the wiring diagram from the 1965 corvette shop manual, supports my memory.
Received 1,857 Likes
I do not have the AIM. This is kind of like when I was a kid, and I used to put my car models together without the instructions I guess.. except now I'm building 1:1 scale ha ha!
Where is a good source to order the 1964 AIM?
