Removing a slightly rounded Hex Socket Plug
Old Dec 26, 2008 | 08:20 PM
Mikey65's Avatar
Mikey65
Default Removing a slightly rounded Hex Socket Plug
I finally started up the car again, and noticed a slight leak from the outlet for the heater hose from the water pump, and the top plus that I had plugged with a hex plug. I reapplied teflon tape to the hose nipple, and attempted to remove the plug at the top of the water pump. It turned about 2 times, and then the plug gave... now the 3/8" is too small, and the plug is in there tight.. anyone have suggestions for removing this thing???
Old Dec 26, 2008 | 08:26 PM
BADBIRDCAGE's Avatar
BADBIRDCAGE
Pull the pump off the motor, have someone apply a spot weld on your allen wrench to the plug (with a TIG machine for max heat) and it will come right out.
Rich
Old Dec 26, 2008 | 08:27 PM
Mikey65's Avatar
Mikey65
Rich
I already thought of that =) ... I was hoping for something that might work without pulling the pump off?
Old Dec 26, 2008 | 09:18 PM
BADBIRDCAGE
If you have availability to the TIG you can do it on the car. Won't hurt anything. Once one of those plugs rounds out on the allen area you are pretty well screwed. Unless you can drill it out successfully and use an easy out. Lots of grease on the drill bit helps catch the chips. IF you have a left hand bit it also helps.
Good luck with it. I don't envy you trying it still mounted on the motor. Labor to R&R the pump is minimal. Might even be faster than trying to monkey di#k it on the car.
Rich
Old Dec 26, 2008 | 11:26 PM
ghostrider20's Avatar
ghostrider20
Any heat on the pump will wreck the seals. You could weld the tool on as sugested. If you don't have a welder, just drive the car there and have them weld it on, then drive it home and remove it.
I would not fart with drilling it out, for the time, effort and brain damage, just pull the pump and buy a new one for 28.00.
Mark
Old Dec 26, 2008 | 11:28 PM
KC John's Avatar
KC John
C2 of Year Finalist (appearance mods) 2019
Have you tried to use a metric allen key in the hole?
Old Dec 26, 2008 | 11:30 PM
KC John's Avatar
KC John
The other thing you might try is to cut a slot across the hole with a dremel and use a large flathead screw driver or a flat piece of steel to turn it out.
Old Dec 27, 2008 | 06:51 AM
Frankie the Fink's Avatar
Frankie the Fink
Army
I've done some amazing things with 'Knock Er Loose' penetrating oil, some heat and large vice grips (if you can clamp them on to the problem bolt!)... If the bolt is located in a depression you will have to use one of the suggestions above..
Old Dec 27, 2008 | 07:19 AM
MikeM's Avatar
MikeM
You may have to dress the sides a little and cut a taper on the end. Then drive it in the plug and turn it out.
Or:
mix up some JB weld or similar and put it in the hex depression and then shove the allen wrench in after it. Let it harden. Turn the plug out.
Or:
Drill a hole between the plug and pump. Run the appropriate size sheet metal screw in the hole. Turn the plug out. Dress up the buggered up pump with a little jb.
I don't really see anything wrong with mig welding the key to the plug if you lay wet rags around the repair to absorb the heat and catch weld spatter.
To Removing a slightly rounded Hex Socket Plug
