Zinc additive
Old Jan 9, 2009 | 02:33 PM
Dr L-88's Avatar
Dr L-88
2025 Corvette of the Year Winner- Modified
2024 C2 of the Year Winner - Modified
2022 Corvette of the Year Finalist -- Modified
2021 C2 of the Year Winner - Modified
2021 C1 of the Year Winner - Modified
2020 Corvette of the Year (stock)
C2 of Year Winner (stock) 2019
2017 C1 of the Year Finalist
Default Zinc additive
Where can I buy some oil additive that is high in zinc for a new engine build? Local Chevy dealer does not carry it.
Old Jan 9, 2009 | 02:43 PM
Frankie the Fink's Avatar
Frankie the Fink
Army
Here is one source http://www.zddplus.com/ there are various racing and diesel oils that purportedly have enough zinc for the old motors.
Please do a forum search and you will find encyclopedias of information about this topic. I hope all those debates do not get started again in this thread.
Old Jan 9, 2009 | 03:00 PM
wmf62's Avatar
wmf62
St. Jude Donor '07
i seem to remember that John Z mentioned that EOS had been discontinued by GM, but then i also seem to remember that it was back under a new part #...
any of the cam manufacturers should have a break-in lube for flat tappet cams that should also provide protection for a new engine rebuild.
otherwise, i'd just get a good diesel oil.
Bill
Old Jan 9, 2009 | 03:14 PM
L78racer's Avatar
L78racer
Should still be available...
GM EOS
Old Jan 9, 2009 | 05:40 PM
Mike Ward's Avatar
Mike Ward
Why not just buy regular oil that has enough zinc already in it?
gonefishn's Avatar
gonefishn
St. Jude Donor '09
Red Line break in oil additive has ~19000 ppm Ph and ~13000 ppm Zn as well as molybdenum.
http://www.redlineoil.com/products_m...1&categoryID=1
Mixes with conventional or synthetic.
Not to debate, but I do put some in (4oz per 6 qt) during a regular oil change too.
If needed I can post the GM EOS number when I get home tonight. As mentioned it changed to a new number but haven't checked it's availability recently.
Old Jan 10, 2009 | 01:10 PM
vettesbydesign's Avatar
vettesbydesign
Rex.....just pickup some Mystic JT8 oil for deisels,and be done w/it,bud.It has good zinc count,and will work just fine.
Old Jan 10, 2009 | 08:56 PM
Dr L-88's Avatar
Dr L-88
OK Kev..............where can I find it?
Thanks,
Rex
Old Jan 10, 2009 | 10:31 PM
vettesbydesign
Thanks,
Rex
I got mine at Farm and Fleet here local in town.I got it on the recommendation of a old drag racer when I just put the aluminum heads on the green car,and new solid lifter cam combo.It was 22 bucks for 2 gallons.My break in went fine.
I had no luck at O'Reilys,or Advanced,and didn't try Autozone,but any kind of Rural King,Farm,and Fleet,or some deisel truck place can get you in the right direction.
Old Jan 11, 2009 | 12:39 AM
buns's Avatar
buns
Competition Cams has a break in lube that should be available at your Friendly Local Auto Parts Store.
On a side note, I have always wondered why the camshaft manufacturers haven't been coming forward with information about the lack of ZDDP in modern oils, since they are probably the first to get blaimed when a lobe gets wiped out. So, lo and behold, Comp Cams now has an article on their website, the 'Flat Tappet Tech Bulletin'.
http://www.compcams.com/Base/pdf/Fla...chBulletin.pdf
Old Jan 11, 2009 | 07:21 PM
Dr L-88's Avatar
Dr L-88
Thanks Buns. That article is very informative, especially since I have 2 new Comp Cams flat tappet cams to install.
To Zinc additive
