big block history? expert needed.
anyone out there know why the 66 big blocks changed casting numbers by sept. of 65?.......numbers went from a 961 to a 942 and the latter was used in 2 or 4 bolt form. i could never figure this out. i actually read years ago that the 961 was actually a bored 962 396 block from 65, but have never really had a reliable source on the subject.....
I'm relying on a foggy memory, but I think the 1965 early 396 blocks had very thick cylinder walls that could easily be bored to 427. I'm thinking the new cast numbers were for the new non-bored 427.
Also, the later 396 blocks could not be safely bored to 427... the walls were too thin.
There is an old story that has been around for years concerning the 427 Corvette.
Who knows if it is true or not.
GM had a in-house rule that certain cars could not exceed 400 cubic inches. Supposedly Duntov convinced Chevrolet upper management that the heavy 396 engine was causing handling problems in the Corvette. He said the car needed to be lighter in the front. He explained that easiest and least expensive way to lighten the car and fix the problem was to bore the engine... to 427.
All 962 blocks were 4 bolt.
All 961 blocks were 2 bolt.
So, the 961 could not have been a bored 962.
942, 351, 321, 439, 270, and 512 were cast both 2 and 4 bolt.
Received 6,592 Likes
C2 of Year Finalist (track prepared) 2019
Nader axed it for '64 (safety guru nader).
I hate that book. The '64 Corvair for which I paid $1200 instantly became worth $200 because of it.
Jim
According to the Muscle Car show I just watched Mitchell wanted it (he designed the car that way) and Zora didn't like it. Mitchell got it for one year. Nader was never mentioned. However, if both Zora and Bill both liked it, then I'd bet it would've been around for at least a few more years.
larry
larry
Search the archives, plenty of info there to put this rumor to rest. Yup, someone snuck one in on Noland's survey of 66's - probably why this topic surfaces every few months since his C2 book was published.
3855961 = 2-bolt only 396cid thin-wall casting. Chevrolet 325hp & 360hp applications.
Over the years I have picked up and moved a lot of blocks, that 961 was always MUCH MUCH heavier than all the rest, including the 962.
I seem to remember 2 and 4 bolt versions, this would be long before people started to convert them for any type of "resto" purposes.
I know the cylinder walls were VERY thick and learned to not even blink at the thought of immediatly punching it out .125" and still have plenty of meat. I do not remember how much thicker the walls were but it was easy to stick a couple of fingers thru a cooling passage hole and the inner cylinder wall and one could very easilly feel how much thicker the walls were when a std 427 block was next to it for comparison, once you did that one time, ya just did not have to do it again with a 427 block next to it, it was that different.
Interesting story about Zora, although I suspect its just Lore, I would suspect it had more to do with bean counters finding out not that much cast iron and nickel was needed.
Anyway, best block in BB version GM ever made in my opinion!
True.
Not true. Ralphie didn't have a voice as early as '64. People didn't start paying attention to him until around '65/'66 when his book, "Unsafe at Any Speed" was published.
Jim
Jim
I have never seen a 961 that would pass the pencil test. Pop a side freeze plug and try to insert a pencil between the cylinders. If it won't go through then it's thick enough for a 427 bore. If the pencil passes between them it is not thick enough for 427. I'm fairly certain that if they made any early 961's for 427 use, they would have to use a 427 inner core.
If in doubt, get it sonic tested.
larry
larry
