Body or Frame?
Old 01-19-2009, 03:59 PM
Woodie
Support Corvetteforum!
Woodie's Avatar
Default Body or Frame?
I'm sure one or more of you guys know.
Why were body shims used?
Was it because the frame were off - twisted from welding or because the bodies were off? Or both?
And how much off could the frames be and still be used?
I'm sure they were not all perfect. Say up to 1/2 inch? Or more?
Old 01-19-2009, 04:06 PM
John McGraw
John McGraw's Avatar
The shims were used to adjust for the frame twisting and warping during welding. The jig that determined the shim count was lowered over the frame, and then the shims were selected. The same jig was used for all cars, so it could not have adjusted for body problems. The shims were selected and taped in place on the chassis long before the body was lowered on to it. I have seen factory stacks of shims (with the masking tape still in place), that exceeded 1/2".
Regards, John McGraw
Old 01-20-2009, 02:22 PM
JohnZ
JohnZ's Avatar
Received 1,859 Likes on 1,102 Posts
Frame fabrication tolerances were +/- 3/8" from nominal datums; the shim packs compensated for those dimensional variations. The body was bolted to a machined steel build truck while it was assembled, and was considered as being "to design".
Old 01-20-2009, 02:45 PM
Harps
Harps's Avatar
John & John, that's great info on this! It's great to hear about the old process on this.
We have two original Survivor cars (a 72 LS5 with 1,700 original miles, and a 67 427/390 car with 30k orig miles). You wouldn't believe how nice the old masking tape is on the 72, its aged in appearance but looks perfect still at each body mount. The 67 has its tape in some places still too, just not as perfect as the 72. It's always great to see original masking tape on a Survivor car.
Old 01-20-2009, 02:49 PM
MasterDave
Moderator
MasterDave's Avatar
And here all this time I thought it was due to the variations of fiberglas thickness on the undercarriage. Bodys were set on the frame, leveled, gaps measured and shims taped on. Go figure....
Old 01-20-2009, 03:07 PM
JohnZ
JohnZ's Avatar
Nope. A master gage fixture measured the gaps from each body mount bracket on the frame to the gage while the frame was upside-down in the first station on the Frame Line, and the operators marked the number of shims required at each mount location on the frame. The chassis arrived at Body Drop about two hours later, and the operators there installed the upper body mount cushions and the corresponding shim pack on each body mount bracket and taped them in place just prior to dropping the body on the frame.
Old 01-20-2009, 03:42 PM
OC-1
OC-1's Avatar
Default original 61 front shim
original front shim on my 61 with tape
Old 01-20-2009, 03:53 PM
hokie04
hokie04's Avatar
I presently have my body off of the frame. So are you saying I can calulate the number of shims I need at each mount before I drop the body? If so is the factory mount heights in the AIM manual or where could I get these measurements? My shims were basically gone when I removed the body so I am just guessing at this point. This sure would be a lot easier than dropping the body on the frame and then trying to fill the gaps with shims.
Old 01-20-2009, 04:01 PM
MasterDave
Moderator
MasterDave's Avatar
So you're saying it was all frame? Why the big difference in shim thickness? Were they that bad at holding specific tolererances?
Old 01-20-2009, 05:43 PM
John McGraw
Yep, it was all frame! As John said, the spec. was +- 3/8" at each location. with this type of spec, it is possible to have 3/4" difference between any two mounts. Not very likely, but possible!
Trying to calculate the shim stack from the frame in a current restoration by using the frame only, would take a lot of fancy measuring equipment and a surface table to mount the frame to. High end frame and fabrication shops would have such datum measuring equipment, but not your average restorer. Setting the shims with the body is not that tough to do, and will give better results on a body which has not been bolted to an assembly plate for over 40 years.
Old 01-20-2009, 05:59 PM
zim64
zim64's Avatar
Ditto John, I rebuilt all the suspension and drivetrain components, then I set my body, then inserted shims to take up the gap, let it set a couple weeks readjusted the shims if needed, and bolted and torqued them in place, all this before doing any body work, as I replaced all 4 wheel openings (flared). I wanted to be sure that the body was settled to the frame before disturbing any panels.
Old 01-20-2009, 06:36 PM
al329
al329's Avatar
Have yet to put my body back on but I will be using this paper as a guide.
http://www.lbfun.com/warehouse/tech_...0C2%20Body.pdf
Old 01-20-2009, 10:35 PM
Vogie
Vogie's Avatar
You might be able to use a water level - a container with small tubes long enough to reach points to be referenced. The water would be at exactly the same height in the container and each of the tubes no matter what position you were measuring and no matter what the condition of the surface on which you were working. Just a thought.
To Body or Frame?
Quick Reply: Body or Frame?
