When you receive that from Speedway (don't they have a lot of "interesting" parts?), I'd like to know if the mount is welded at more than just the two places visible in the photo. Could you post a follow-up picture of the actual mount they send?
Jim
I found another plate that has possiblities, not sure I want to run a pure front motor plate and transfer all that vibration.
From: The problem is all inside your head she said to me.
Originally Posted by muncieman
I think the problem is going to be the that the mount is far lower than the original mount, nearly in line with the two lower bolt hole in the block. The stock mount lines up with the water pump holes
I'm going to get one, not all that pricey, and have a look at what needs to be done.
Jim- I'm with you, good lord you would hope so and it probably is in sections on the back.
Muncieman- You may also end up making new lower frame mounts to rest that on.
