will it explode?
Old Feb 9, 2009 | 10:50 AM
joshtried's Avatar
joshtried
St. Jude Donor '08-'09-'10
Default will it explode?
so, ive got a 54 that im stuffing a 350 into, with hookers, and the hookers come about 1" from the battery. does anyone know how close is to close when it comes to heat and batteries. did chevy move the location of the battery for later C1's that had a v8? if they did, can someone tell me where it was moved to?
Old Feb 9, 2009 | 11:51 AM
jimh_1962's Avatar
jimh_1962
2018 C1 of Year Finalist
Move the battery into the trunk... there are some of the member's put the battery in the trunk.
Old Feb 9, 2009 | 12:01 PM
firstgear's Avatar
firstgear
2019 Corvette of the Year Winner
St. Jude Donor '15
here is a link to over 1000 photos of my car from start to current...mine is a '60
http://public.fotki.com/htmiata/1960_corvette/
Battery pocket located just left of the spare tire wheel well
Gel type battery and mounting box from Summit Racing
Battery terminals through bulk head, cables and rings from Detroit Speed and Engineering. They will sell you what ever length battery cables you need.
Good luck!
Herb
Old Feb 9, 2009 | 01:02 PM
emccomas's Avatar
emccomas
Your car is pink?
Old Feb 9, 2009 | 02:03 PM
firstgear's Avatar
firstgear
St. Jude Donor '15
Originally Posted by emccomas
Your car is pink?
yes, it is a Mary Kay car....of course! One of only 5 made that year, very valuable.....
Old Feb 9, 2009 | 03:03 PM
1955 copper's Avatar
1955 copper
2015 C1 of Year
WOW that is a first class job
Old Feb 9, 2009 | 04:44 PM
Trophy Blue's Avatar
Trophy Blue
Does it have the L-88 option as well?
Old Feb 9, 2009 | 04:47 PM
Dan Hampton's Avatar
Dan Hampton
Firstgear is correct. The color was RPO 'ELF', ordered by Elfie Duntov to be used as her daily driver.
Old Feb 9, 2009 | 08:29 PM
haccpguy's Avatar
haccpguy
54 Vette Rod
Please post pics of your progress. Should be very cool when done.
Guy
Old Feb 9, 2009 | 09:05 PM
paulywannafly's Avatar
paulywannafly
nice job tucking that battery in looks like it belongs there
Old Feb 10, 2009 | 12:22 AM
firstgear's Avatar
firstgear
St. Jude Donor '15
shhhhhhh
Old Feb 10, 2009 | 05:26 AM
joshtried's Avatar
joshtried
pics coming soon. all are on the wifes phone for now.. really wasnt looking forward to moving the battery to the back... but figured it would happen considering how close the headers are.. i think the pass side header is actually currently in contact with the battery box.. wonderful. on a plus side, i got the tranny bolt in place. only took a neighbor and me wife to push the motor back.. why you ask?? cause my headers are to friggin long!! frames gonna have to be cut for exhaust to go in.. me thinks i bought some stuff a bit prematurely.. but i love em!!
Old Feb 10, 2009 | 06:45 AM
rahaul's Avatar
rahaul
Let me guess. The cigarette lighter dispenses lipstick.
Old Feb 10, 2009 | 06:47 AM
rahaul's Avatar
rahaul
Old Feb 10, 2009 | 11:09 AM
Russ T Gate's Avatar
Russ T Gate
I would think that if you had a inch of clearance and the battery is in a battery box, you could use header wrap on the offending pipe and place some heat reflecting insulaltion in the box between the battery and inside wall of the box. I would also use a gel battery instead of a acid batt.
Good luck
Russ
Old Feb 10, 2009 | 11:57 AM
ZLX's Avatar
ZLX
I have seen batteries catch fire during recharge w/a battery charger.
The gas emmitted by lead acid batteries is flamable. Most of the time
you are fine/safe.. but if you got a bad battery or into a overcharging situation and smelled the "rotten egg" sulfur smell- which occurs when
gas is being emmitted you've got flamable gas around... at that point
an ignition source with a sufficiently thick gas clould equals fire.
I think very probably during driving when you're going to have air
circulation because of the movement of the car you'd be fine.
An inch away might be close enough to do some melting...
Most of the batteries back in the 50's/60's didn't have alot of
cold cranking amps.. 350 was the norm... a Honda group 54 battery
will have 450 to 600 cca's and has a very narrow profile.. about 1/2 as wide as most batteries. I have used Group 54's with V-8's and they
perform just fine... you won't have any issues in performance or longevity. You could likely pick up an extra 5 to 7 inches
of clearance with a Group 54... just trying to give other options here
as the trunk placement has been covered.
Old Feb 10, 2009 | 04:53 PM
FASTZ's Avatar
FASTZ
it seems to fit you
To will it explode?
