I ahve a 300 hp 327 and was recently mapping my timing. and determined my centrifugal advance is advancing way to much. After researching I have determined that a bushing on the pin that goes through the breaker plate is missing. My question is where to get a bushing and how is it held in place? Thanks for any response.
If it were mine, I'd be afraid of a little brass bushing getting loose in there. I'm sure it's overkill, but I'd also crimp it; solder it; epoxy it; and, anything else I could think of.
I make my own brass stop bushings. I make them in a variety of diameters, so that I can "tune in" any total cent. advance that I want. Have always pressed them on (good interference fit), and never had one come off. I suppose a little Loctite would not hurt (if it was a loose press fit, but I always make sure my bushing are "tight".
Small hairpin clip, or a small c-clip/horseshoe slip.
Larry
The pin on the autocam for the bushing didn't have the groove for the clip until later in the C3 era; prior to that, the pin was plain, and the bushing (or original rubber bushing) just pressed on the pin.
I just looked at my 66 L79 distributor. I do not see any brass or rubber bushing anywhere I look. Are there pictures anywhere to show me where to look to be sure I'm looking for it in the right place?
I have a brass one from a tuning kit hanging around. If it is supposed to be where I think it is, would this brass bushing just press onto the pin by pushing it up from underneath the plate with my fingers?
And will a brass bushing stay there with just the friction from the press fit?
Any advantage of a brass bushing over the rubber ones I see in the LI Corvette catalog?
Yes, the bushing installs on the pin from below - see photo below of the pin. The original bushings were hard rubber, and most fell off after a few years (until they added the groove and C-clip in the 70's). The brass aftermarket bushings have a light interference fit and will stay in place by themselves.
Be aware that there are several sizes (diameters) of the aftermarket bushings, and that diameter (and the length of the slot in which it travels and the contour of the tails on the weights) determines the maximum centrifugal advance.
You're looking for around 24* of centrifugal advance so you can run 10*-12* initial and stay between 34*-36* total timing.
perfect. thank you. with the aid of a mirror i now see a rubber one up there, so i think i'll leave it alone. i've read the aftermarket kit weights aren't as good as the stock ones. how can i tell if i have stock weights?
