Paint code question
Old Feb 10, 2009 | 03:14 PM
MasterDave's Avatar
MasterDave
Moderator
Default Paint code question
Anyone have the paint code for 54 Sportsman Red and Polo White? Not sure which brand to use and need suggestions. Thanks
Old Feb 10, 2009 | 03:41 PM
W64N's Avatar
W64N
There is a comprehensive list of paint codes at this website.
http://www.corvettepaintcodes.com/
Hope this helps.
Old Feb 10, 2009 | 04:27 PM
MasterDave's Avatar
MasterDave
Moderator
Perfect! Thanks
Old Feb 10, 2009 | 04:28 PM
53 Blue Flame Brett's Avatar
53 Blue Flame Brett
Dave, I am going to the Dupont Auto Paint store tomorrow. I can get you Base Coat/Clear Coat codes if you want them.
Old Feb 11, 2009 | 10:36 AM
MasterDave's Avatar
MasterDave
Moderator
That would be great Brett, the painter I met with last night says he uses Sherman Williams. He's going to check today to see if they cross reference to Dupont.
Old Feb 11, 2009 | 10:40 AM
53 Blue Flame Brett
I'll have the codes in a couple of hours.
Old Feb 11, 2009 | 11:14 AM
gbvette62's Avatar
gbvette62
The NCRS' original Specification Guide book, first printed in 1989, included paint numbers. It shows the original nitrocellulose lacquer numbers as follows:
Sportsman Red: DuPont = 1905-H, Ditzler = DAL70418
Polo White: DuPont = 1783-H, Ditzler = DAL8011, RM = 54V91
I don't know if this will help, but I figured it couldn't hurt.
Old Feb 11, 2009 | 11:54 AM
MasterDave's Avatar
MasterDave
Moderator
I just pulled the top protection foam off the fuel tank cover and man, it's a pretty dark red. That's the correct color for the exterior as well?
One year only?
Old Feb 11, 2009 | 01:55 PM
53 Blue Flame Brett
One year only?
Do you have a picture?
Old Feb 11, 2009 | 02:10 PM
1954corvair's Avatar
1954corvair
One year only?
If you need red and white to spray and match, I have 4 cars that have been painted the red interior and white exterior. I have extra paint and will be glad to provide it to you free of charge. This gloss level is different for places on the car and I can gladly share that with you also.
Old Feb 11, 2009 | 02:31 PM
MasterDave's Avatar
MasterDave
Moderator
No Way! PM sent...
Old Feb 11, 2009 | 02:35 PM
MasterDave's Avatar
MasterDave
Moderator
I'll snap one this afternoon.
Old Feb 11, 2009 | 03:49 PM
53 Blue Flame Brett
Default Correct Color Codes
MasterDave, here are correct color match codes for Polo White and Sportsman Red. The color was matched to "original" samples taken from an original 1953, #130, from areas that were not normally seen by the sunlight.
These codes are 100% correct, regardless of anything else.
Dupont Chromabase, Base Coat/Clear Coat
Polo White - P1923K
Sportsman Red - C9236K
Dash Top Red - Should be flat
I normally flatten down the trunk and conv top areas just a bit, taking into consideration that these areas were not buffed at the factory. Not as flat as the dash top though. This can be accomplished with a Matte Clear from Dupont.
I leave the steering column and steering wheel a normal gloss as the rest of the car.
Polo White door jams - I normally use the Matte Clear on the door shells and jams, since these areas were not buffed. This is accomplished by rolling back the tape so there is not a sharp edge when done spraying.
If you need the formula for an exact Pennant Blue match, I can email it to you, along with the tan for 1954.
Good luck with the project and please keep posting pictures.
Old Feb 11, 2009 | 04:04 PM
MasterDave's Avatar
MasterDave
Moderator
Polo White - P1923K
I normally flatten down the trunk and conv top areas just a bit. Not as flat as the dash top though. This can be accomplished with a Matte Clear from Dupont.
Thank you Brett. I'm going with Sportsman red exterior so the jambs, etc would be red, right?
Old Feb 11, 2009 | 04:05 PM
53 Blue Flame Brett
Yep
Old Aug 18, 2021 | 01:28 PM
Oseman's Avatar
Oseman
Bret, do you know if the early 53's used Sportsman red or was if it was another color? I was told by a well known restorer its code 4998 medium red, which is a little darker.
Old Aug 18, 2021 | 06:41 PM
silver837's Avatar
silver837
No disrespect, but this is a12 year old thread. You would be much better off to start a new one . Also if you update your profile to show where you are you will get more responses from people near you.
Old Aug 19, 2021 | 03:01 PM
csherman's Avatar
csherman
2026 Corvette of the Year Winner - Unmodified
2025 C1 of the Year - Unmodified Winner
2019 C1 of Year Finalist (stock)
2018 C1 of Year Finalist
Other way around - the 53's were a lighter red - has alot of white in it
The 54's are darker.
Old Aug 19, 2021 | 07:10 PM
vettebuyer6369's Avatar
vettebuyer6369
You are adding in to a post from 12 years ago. Please start a new thread with your question.
To Paint code question
