Spin on filter
Old Mar 7, 2009 | 11:18 AM
macs65's Avatar
macs65
Default Spin on filter
I am currently using the stock cartridge oil filter on my 327. Considering replacing with the bypass adapter and a spin on filter. Corvette Cenrtral sells a kit. Anyone had any problems doing this??
Is there any benifit to changing to a spin on other than mess the cartridge cause during an oil change??
Old Mar 7, 2009 | 11:54 AM
66BlkBB's Avatar
66BlkBB
St. Jude Donor '13-'14-'15-'16-'17
I put the spin on my car over 20 years ago. I makes changing oil a lot easier. You don't have deal with the cartridge filter or cleaning out the canister. JMO
Old Mar 7, 2009 | 12:14 PM
Frankie the Fink's Avatar
Frankie the Fink
Army
Absolutely put the spin-on adapter on - I nearly lost my original engine because of a munged gasket in the cartridge after an oil change...lost 3 quarts in the street. Plus, if you use the NAPA 1060 'Gold' large capacity filter (its all black with no labeling by the way) it darn near looks like the old canister. Here is a picture - a little fuzzy but you get the idea.
Old Mar 7, 2009 | 01:41 PM
StingU2's Avatar
StingU2
Makes changing oil a snap... and the big plus is less mess. I too use the NAPA Gold 1060. You can also use the NAPA Gold 1069 which is a shorter filter than the 1060. The 1060 and the 1060 from NAPA are the same as the AC Delco PF25 and the PF35 filters.
Old Mar 7, 2009 | 03:08 PM
macs65's Avatar
macs65
Thanks for the info, when doing the switch over do you have to remove the original filter and O ring holder, or does the adapter fit over the original part??
Old Mar 7, 2009 | 03:24 PM
Frankie the Fink
Army
I don't remember exactly but I think you get a new O-ring with the kit and the adapter seats up in the old canister mounting spot with two bolts (I put Lok-Tite on them). Its pretty straightforward once you have the spin-on adapter in your hand to look at. You can also use a PF-1218 filter in a pinch but I prefer the looks of the NAPA 1060 Gold...
Frank
Old Mar 7, 2009 | 03:29 PM
midyearvette's Avatar
midyearvette
Frank
some of these adaptors mut be used with the original by pass unit that comes with the canister filter....be careful here........if your adaptor does not have a by pass, then you must use the old by pass between the block and the new adapter!......
Old Mar 7, 2009 | 03:42 PM
Frankie the Fink
Army
This is the exact kit I used:
http://www.ecklers.com/product.asp?p...75&dept_id=153
Old Mar 7, 2009 | 03:50 PM
midyearvette
that is used in conjuction WITH the original aluminum spacer for the canister filter. remove the original adapter to install the new o ring and then BOTH pieces go back in the block and i think with a smaller seal between them......it's been awhile......if you don't use both, then the oil from the pan does NOT circulate through the filter.......
Old Mar 7, 2009 | 04:15 PM
Frankie the Fink
Army
Exactly right - I remember now....one of those jobs that required 3 hands...
Old Mar 7, 2009 | 05:11 PM
ghostrider20's Avatar
ghostrider20
That's the Mr. gasket kit I think. I used that one as well. You have to remove the bolts holding the bypass and use the longer bolts supplied, that also hold the adapter in place.
Old Mar 7, 2009 | 05:34 PM
macs65's Avatar
macs65
I tried this once before several years ago. I bought an spin on adapter kit (only)from a local speed shop. Installed it and had major leaks. so I went back to the canister. This time I have ordered a ''bypass adapter valve and the spin on kit" as directed in the Corvette Central book.
Old Mar 7, 2009 | 06:29 PM
Frankie the Fink
Army
That should do it -- mine works flawlessly. remember to Lok Tite the big threaded central part of the kit that the filter screws onto as well as the two longer bolts that holds the adapter plate on.
Old Mar 7, 2009 | 06:34 PM
macs65's Avatar
macs65
Thanks I will.
Old Mar 7, 2009 | 10:31 PM
TX63CONV's Avatar
TX63CONV
I have a similar adapter and I thought I read a post that you did not need the bypass with today's spin on filters.
Old Mar 8, 2009 | 07:58 AM
Frankie the Fink
Army
If the filter gets clogged and that is the oil's only circulation path you'll need a bypass somewhere...in the oil filter itself or in the mounting arrangement. Its moot anyway as the kit I cite above requires keeping the original bypass...as midyearvette noted.
Old Mar 8, 2009 | 08:20 AM
Hitch's Avatar
Hitch
That one will work but I always worry about the threaded part unscrewing. So I like this one that is all one cast piece. This one looks a little bit different than the one I bought five years ago...
http://www.jegs.com/i/Perma-Cool/771/01135/10002/-1
To Spin on filter
Old Mar 8, 2009 | 08:36 AM
Frankie the Fink
Army
That one states that it eliminates the bypass (don't know if that's what folks want) but it does have a more secure central threaded piece. I'm OK with my Lok Tited in part and have changed the oil 3 (4?) times since its installation with no problems.
Old Mar 8, 2009 | 08:49 AM
Hitch's Avatar
Hitch
I agree some may not want to eliminate the bypass but if I understand spin on filters they all are designed to bypass if clogged. So with that being said do you really need a bypass once you put a spin on filter?
Dave
Old Mar 8, 2009 | 10:35 AM
macs65's Avatar
macs65
When you mention appling Lok Tite, are you speaking to appling the lok tite to the female thread in the spin on filter so that it does not back off???
