Wow -- another huge PITA job that starts out small and takes all day. I don't know how I managed not to screw this up and ding the snot out of the tinny pieces but it looks like I may have lucked out. Grinding off the top and bottom trim strips was hard on the old eyes and I just 2-part epoxied them back on the new center strip...I'm hoping that's plenty to hold it on. Now just have to reinstall without tearing up the dash pad...
Good job Frank. When I did mine I chickend out and had Va Vetts do it. Good luck with the install.
Spent the day detailing the '62 as I will be putting it in the Richmond Int Auto Show tomorrow. Will be next to the GM display and they promised to have a new ZR1 on display.
Looking at your pictures brings back bad memories.
26 years ago I was trying to separate the stainless trim from the aluminum insert, using a small screw driver. To this day I still have a scar in my left hand where the screw driver slipped and I drove it 2" into my palm.
Yours however does not appear to have any blood on it.
I just used some heavy produce (celery, aspargus, etc) rubber bands and banded the snot out of it while the epoxy cured.
Made sure the rubber bands were NOT where the epoxy was, I used three sets of bands,and epoxied three places each, top and bttom, used a thinner runnier clear epoxy that would flow into the seam between the trim chrome and the insert backplate after everything was banded and compressed and set into place.
those little trim pieces on either end of the grab bar are a real PIA and will mar the ends of the aluminum insert VERY EASILY. So be careful when you reassemble.....it is not fun....the fun is yet to come!!!
good luck......
That's part of why I'm replacing this piece, in addition to being dinged up generally....I cranked down good and hard on the grab bar brackets after installing my new dash pad 4 months back and guess what that did...
Got the new insert into the dash last night with no damage...putting cardboard under the sharp tips at the end of the insert sure saves holes in the dash pad.
Earl
Of course, you are going to post some pics...Earl!
That is very helpful. I wonder if it matters much about using epoxy over a spot weld. I would think it would prevent color distortion in the metal using epoxy. How long do you think the epoxy would hold up over time?
I used basically the same procedure that was in the video except NO spot welds or brazing....I would find it hard to believe this trim piece will not stay together for decades with just two part epoxy and I wanted to make life a little easier for some future owner.
My problem now is the fit into the dash pad...I glued the bottom lip of the pad up a little higher under the insert hole to avoid exposing a cut spot in the dash pad and now the whole insert is in slightly crooked and the grab bar brackets don't seat well into the insert. I'm taking a break and doing some other stuff and will try finessing that issue later on.
best to walk away and come back and fight another day.......less chance of making a frustration based opps!
I seem to recall getting it back into the new dash pad was twice as frustrating as refinishing the insert... I had to walk away at least twice to ensure I did not rush it... and ruin all of the tedious time already invested...
Well the insert is in now and looks decent but not perfect - but hey they weren't perfect when they were new...the grab bar brackets are just a tad lower than they should be on the insert but more screwing around probably will not help enough to make it worth it...
Congrats! When I did my 60, I did everything. I did the suspension, drivelne, moter, heater, wiper transmissions, seat frames, windshield, etc. I had the insert done.
Now, if I could just get the nerve up to start on one of the tops!
Larry
Larry
I try to do nearly everything except 'heavy' engine/tranny/differential work. I don't have a lift (nor the expertise). I'll tackle most anything else... It just seems like it takes the 2nd or 3rd time before you get the technique and tricks right on these restoration tasks. No substitute for experience I guess....and reproduction parts don't make life any easier either.
Yesterday, I put together the insert. It really was not that bad. The hardest part was to remove the stainless steel without making any major marks to the stainless. I sandblasted and painted the housing then cleaned up the inside of the two mouldings. It seemed to help when I put the new insert into the housing. I did not have to use clamps, tape or rubberbands.
I did put a couple of small nicks into the top of the stainless steel moldings when removing the old dash insert. I was able to buff most of it out.
Yeah I had a small scratch in my top stainless strip....I rubbed it out (mostly) and its good enough. You get 'target fixation' sometimes on the small details and have to step back and get the big picture.
Sitting in the car now and sweeping an eye across the interior it d@mn near looks flawless
Drove my C1 200 miles Saturday to two different car shows and
the compliments and positive remarks help offset some of the frustration and pain. This ole 283 is really running fine now...
Also, can I use acetone on the aluminum insert? I need to remove some finger prints (I must had a small amount of epoxy on my hands).
The left end has some minor dimples which I believe is covered up by the dash end cap.
I doubt there are many of these inserts that don't have some sort of small scratch or dimple somewhere - they are terribly fragile. I don't know about acetone but it may be all right.
I am a big fan of Ooops!, a product I buy from Ace Hardware, I've removed dried putty from house carpet, weatherstrip adhesive from door panels and contact cement from my dash pad and never hurt a thing. Wipe it on, immediately start rubbing, dry the area and then rinse lightly with water, repeat as needed...its never failed me yet.
