Holley's......
Old Apr 4, 2009 | 02:16 PM
vettesbydesign's Avatar
vettesbydesign
Default Holley's......
I priced all these w/shipping included,and tried to make sure that I could beat all the big boy mail-order companies,so.......
The Dominator's are all available,also,but not listed,and if you want to finish off the induction setup w/new intake......just let me know which one,and will save you some coin,land throw in a set of fel-pro intake gaskets for free.
If there is something that ya all would like a sale on....please,let me know,and will whoop one up for ya all.It doesn't matter what it is,as long as it is performance related,and one of the top named companies....CAN GET!!!!
*STREET AVENGER'S*
570 cfm,man.choke...355.00
570 cfm,elec.choke...377.00
670 cfm,man.choke...370.00
670 cfm,elec.choke...381.00
770 cfm,man.choke...390.00
770 cfm,elec.choke...401.00
870 cfm,man.choke...441.00
870 cfm,elec.choke...460.00
*4150 DP's*
600cfm...360.00/shiny...391.00
650cfm...366.00/shiny...425.00
700cfm...402.00/shiny...455.00
750cfm...450.00/shiny...510.00
800cfm...485.00/shiny...560.00
850cfm...500.00/shiny...572.00
*4150 STREET HP Carbs*
650cfm DP...510.00
750cfm Vac.Sec...535.00
750cfm DP...535.00
*4150 HP Carbs*
600cfm,mech.sec.,str-leg boosters...690.00
650cfm,mech.sec.,str-leg boosters...690.00
750cfm,vac.sec.,down-leg boosters...690.00
750cfm,mech.sec.,down-leg boosters...690.00
950cfm,mech.sec.,down-leg boosters...728.00
1000cfm,mech.sec.,down-leg booster...758.00
1000cfm,mech.sec.,annular boosters...793.00
*ULTRA 4150 HP Carbs*
650cfm...880.00
750cfm...920.00
950cfm...915.00
These are WITH shipping INCLUDED to your doorstep in the US lower 48.If you are from aboard....pm me,and we will get you taken care of.Not trying to make money on shipping....
Old Apr 5, 2009 | 12:19 AM
zpletcher's Avatar
zpletcher
Default Holly Carb
Which carburetor would match up with my car.?
I don't see it here..
Book shows my original carb was 4160 List # 3370 Holly Part #3882835 EO
66 427/390 4 spd No A.I.R. Stock motor
Was this carburetor (4160) electric choke with vacuum secondaries?
How many cfms did the original 4160 on my car have?
Thank you for any info..
Zale
Old Apr 5, 2009 | 09:19 AM
66BlkBB's Avatar
66BlkBB
St. Jude Donor '13-'14-'15-'16-'17
Zale
I believe that the original carb on the 390 was a 500 or 550 cfm unit. Isn't the original carb. number supposed to be a 3606 and not a 3370? No, the original unit did not have an electric choke. It had the metal spring and rod assembly in the intake manifold that opened up the choke when it heated up. The original carb had a vent on top of the front float bowl that closed when you stepped on the accelerator. Rear was fed by a metering plate and not a metering block. It was a side hung float carb with a tube assembly to feed the rear bowl.
I bought a Holley OEM replacement for my car and it really didn't work worth a damn. I then tried a Holley 3310 on my car and that wasn't worth a damn either. I finally installed a Weiand intake and a Holley model 0-4776 DP (600 CFM) and installed it. The car runs great. Uses a little more fuel when I step on it but the engine runs perfectly with this carb.
Old Apr 5, 2009 | 04:07 PM
JohnZ's Avatar
JohnZ
The carb for that application was a 3370, as noted in the original post (the 3606 was only used on that engine with A.I.R.); it's a 585CFM model 4160.
Old Apr 13, 2009 | 12:58 AM
vettesbydesign
To Holley's......
