Polishing Chrome
Old Apr 23, 2009 | 09:54 PM
TX63CONV's Avatar
TX63CONV
Default Polishing Chrome
I am thinking about polishing my inside and outside windshield surround while I have all of the pieces off. Can anyone recommend what type of rubbing compound and where to get it?
Are any of the "chrome polishes" (meguiars, turtle wax) any good?
The trim is in pretty good shape, just dull.....
My thought was to use the polishing wheel on my bench grinder.
Any advice?
Old Apr 23, 2009 | 10:14 PM
Bill Irwin's Avatar
Bill Irwin
Be VERY careful with a bench grinder and wheel. Try your hand first. There ain't much chrome there. Bill.
Old Apr 23, 2009 | 10:18 PM
Redbird's Avatar
Redbird
2021 C2 of the Year Finalist - Unmodified
2016 C2 of Year Finalist
I use a product by Eagle One called Nevr-Dull. Very good on chrome/stainless. You can get at Wal-Mart or O'Reilleys. Makes my 62 look nice....John
Old Apr 23, 2009 | 10:38 PM
GCD1962's Avatar
GCD1962
Chrome is very fragile ! Do not use harsh abrasives or compounds. Use recommended chrome cleaners & polishes. I've always used Neverdull and you then use a regular car wax.
Old Apr 23, 2009 | 10:52 PM
65 vette dude's Avatar
65 vette dude
If you don't want to get too aggressive,try Wenol in the blue tube,and a 4" cotton buffing wheel on a drill. Finish with Meguires Gold Class wax,hand applied.
Old Apr 23, 2009 | 11:13 PM
Stingray1967's Avatar
Stingray1967
I'd suggest 3M Metal Polish and Restorer. Worked GREAT for some of my parts.
http://www.shop3m.com/60980035525.html
Old Apr 24, 2009 | 10:25 AM
Red63SW's Avatar
Red63SW
Simichrome and Mother's are both excellent chrome polishes, in my experience.
Old Apr 24, 2009 | 10:46 AM
Mark Lovejoy's Avatar
Mark Lovejoy
Those pieces are stainless steel, not chrome plated.
You will work very hard to buff them by hand, you really need a buffing wheel and rouge to do the job correctly. Buffing SS is not easy and very time consuming. Do you know anyone in your area that can do it for you?
Old Apr 24, 2009 | 12:48 PM
ptwohey's Avatar
ptwohey
The guy who polished my stainless used a large cotton buffer pad mounted to a benched motor. He also used one buffer to "cut" the surface then changed it to bring out the shine. They came out looking like chrome. I noticed several different rouges on his bench including green, while and red.
If you have never used a buffer before, practice on scrap. I have seen pieces fly through the air after being caught and the metal also gets hot so if you are not wearing gloves and let go, disaster strikes; and don't wear loose clothing. One quick tug on a shirt sleeve that gets caught on the wheel and you may get your head buffed as well.
Old Apr 24, 2009 | 02:27 PM
Gman58's Avatar
Gman58
Default Non Abrasive
Wash your chrome thoroughly. Pick a polish with no abrasive in it. Never dull works great but leaves a film even so I have been using it since the 60's. I use cotton diapers for a final wipe. Semichrome is also a good product I don't believe is has any abrasive in it and I have been using it for years as well. I do use a high quality wax sometimes. I am kind of repeating what someone said earlier but I thought I would add my comments. My chrome is original and still looks good for a car built in 58. Greg
Old Apr 24, 2009 | 02:37 PM
my58's Avatar
my58
It is also very expensive to repair, so be very careful with it! It is very easy to bend and tweak it, when you buff it.
Old Apr 24, 2009 | 02:42 PM
Roger Waring's Avatar
Roger Waring
I use Turtle Wax ICE liquid car polish on my chrome, stainless and paint. I never have used it on rubber, plastic, or vinyl, but it works great on paint, chrome, and stainless
ICE® is a clear wax formulated with completely new technology that blends silicone and hydrocarbon polymers to provide extraordinary shine and durability.
Product Benefits
  • Can be applied to all exterior rubber, plastic and vinyl trim to restore color and shine without leaving white residue.
  • Unlike conventional waxes, ICE™ can be applied in direct sunlight or on a hot surface without streaking or wax build-up.
  • A single application will provide extraordinary shine however, multiple layers will further increase depth of gloss and shine.
  • Formulated with light stabilizers to protect your car’s finish from the suns damaging UV rays.
  • Complete kit includes a custom applicator and microfiber towel.
Old Apr 24, 2009 | 08:00 PM
jdk971's Avatar
jdk971
try toothpaste for polishing. then wipe with cotton cloth or those miracle cloth stuff. also try it on headlight lenses and plastic. try small area first.
Old Apr 25, 2009 | 10:45 PM
65 vette dude
Actually, I believe the exterior moldings are stainless,but they are flashed chromed for durability,and ease of maintenance . If you are too aggressive with the polishing,you will polish the flash chrome off. Or if you try and wet sand light scratches out, you will quickly remove the flash chrome layer. The stainless can be polished to a high shine,that will look just like chrome,except it will have a slight yellowish tint to it, where chrome will have a blueish tint.
Old Apr 26, 2009 | 08:44 AM
Airetime's Avatar
Airetime
Any advice?
First and foremost be very careful with the trim pieces as they are not chrome but thin SS. I had mine out and they still had the fasteners so I used a long cardboard box and punched holes in the cardboard when I pressed then down which secures them. I used a Dremel with both Mothers Polish and Blue Magic metal polish and they came out very nice
Old Apr 26, 2009 | 11:16 AM
sub006's Avatar
sub006
Mother's was originally made for the motorcycle market. It's quick and easy.
(With 0000 steel wool, it will bring bare steel or pot metal to a mirror finish)
Old Apr 26, 2009 | 11:36 AM
project63's Avatar
project63
Ding Ding Ding.... We have a winner folks!! You can see the spot towards the middle of this old bent up piece of scrap where the flash chrome is buffed off.
Here is a pic of a piece of buffed stainless and one with the flash chrome reapplied. Unless you do this, the stainless will oxidize over time and loose it's luster.
Areba Chrome used to do flash chrome work, Not sure who does anymore now the Rick Applegate sold out. If anyone knows, I'd appreciate a heads up.
tc
Old Apr 26, 2009 | 10:37 PM
TX63CONV's Avatar
TX63CONV
Thanks guys for all the responses! I'm glad I didnt set off with my bench grinder and ruin them.....
I'll try by hand first and see how they come out.
To Polishing Chrome
