Variable H pipe?
The H pipe gained me a ton of torque below 3000 RPM and lost me 30 ft-lb between 3000 and 4000 RPM and also over 5500 RPM.
I was thinking about getting a cutout valve, like Quick Time Performance makes, and adapting it into the middle of my H pipe, so the H pipe can be turned on or off., them using an extra output on my EFI ECU to activate/deactivate the valve starting about 2800 RPM, thus closing the H pipe over 3000 RPM, giving me both my increased low end torque when teh valve is open/H pipe operational and restoring the midrange and top end torque with the H pipe closed.
Anybody know of any other exhaust pipe valves that may work?
Thanks,
Doug
The concern is much like issues I had when I ran an Old's switch pitch T400 in my GTO. The torque converter slip varied from 4% with a 1600 rpm stall (on the tight end) to 12% and a 3200 rpm stall (on the loose end). The full pitch change took about ten seconds, too long for actuation in 3rd gear. I ended up using a second brake light switch to power the solenoid for the loose pitch, a switch that held the solenoid during staging and then released to allow the TC to switch to cruise pitch as I barreled down the track. I took a few more seconds than normal staging, and I gained a reputation for being the last to trip the second staging light.
It worked well, very well with a N2O trigger off a second trans kick down switch on the throttle linkage, but it was not consistent enough for serious bracket racing (what I was into at the time). I could cruise and get 18 mpg (with 3.73 gears), and still run 14 second ET's on street tires with the 400 (significantly under 13-second ET's with the N2O).
How fast do you need (or want) the valve to close?
I suspect the motorized gear drive ones are slower, i will contact manufacturers for info.
I can always build a simple valve with a couple bushings welded to the pipe, a shaft and a throttle plate,and use a lever actuator and put a solenoid on it. It doesn't heve to be absolutely air tight as exhaust will be on both sides, it just needs to shut off 95% or so of cross flow.
The above is probably the simplest for install,as I already have a V-band clamp removable H pipe,and adding a some bearing bushings at one end for the cross shaft wouldn't change any dimensions or require a bunch of exhaust welding. (plate would be at one end of the H pipe to allow access to install the throttle plate, I do not think a larger dead area on one side of the pipe vs the other, when the plate is closed, will make a difference between one bank of cylinders vs the other bank, as we are taking about 3" on one side and 12" on the other)
Doug
Thanks,
Doug
If you were to "plug" the H-pipe "in the middle," would it really give back this hp?
For all we know, perhaps the hp loss is not due to the intermixing of L/R gas, but from the turbulance at the intersection of the "H." Adding a "restrictor" at the center of the H-pipe does little/nothing to alleviate these turbulances so may not give the "payout" you are hoping for.
You actually don't get that much turbulence from a plugged side passage, at least in process plant piping.
If turbulance was an issue, I would think that the 4000-5000 RPM range would be lower as well with the H pipe, instead it is the same as no H pipe.
You don't actually get gas intermix from left to right with an H pipe, instead, you get pulse pressure alleviation, scavanging and reversion effects, most of which is not really understoood by about anybody, even me.
Doug
Doug
The actuator decision will end up much like the H-pipe placement, a compromise, what will work will fit the valve or damper (it's all about logistics and working with what's available).
The project sounds fun.
Well I wouldn't go that far.
Actually, based on my dyno numbers (I have an H-pipe), I find it hard to believe that you loose a bunch of hp in the range mentioned. Maybe it is the placement of the crossover tube, it's size, the exhaust piping size, or ???
I run headers, mandral-bent 2.5" exhaust tubes (including the tips), and a 2" H-pipe crossover. My H-pipe:
And my dyno pulls. Note how smooth they are and there are no spurious humps or drops in the ranges noted.
Now, with that H pipe, even though it lost some power from 3-4K RPM, it flattened the torque curve to about as flat as I have ever seen, as in a 90% torque curve from a little over 1500 RPM all the way to about 5600 RPM, on a 9.5:1 CR motor
Without the H pipe, its 90% torque curve was about 2800-5600 RPM.
Doug
