Header question
Old May 28, 2009 | 09:32 AM
Dr L-88's Avatar
Dr L-88
2025 Corvette of the Year Winner- Modified
2024 C2 of the Year Winner - Modified
2022 Corvette of the Year Finalist -- Modified
2021 C2 of the Year Winner - Modified
2021 C1 of the Year Winner - Modified
2020 Corvette of the Year (stock)
C2 of Year Winner (stock) 2019
2017 C1 of the Year Finalist
Default Header question
What are the best header gaskets for aluminum heads and which header bolts are best? Any locktite required on header bolts?
Thanks,
Rex
Old May 28, 2009 | 10:06 AM
shft22's Avatar
shft22
I have headman headers and have had good luk with their gasket......I do have to re-tight the header bolts every month or so, I don't think Locktite will work since it get really hot there, there are some specialty bolts with lock washers and sort that suppose to work, but I have no experience with them
Old May 28, 2009 | 12:30 PM
redred65cpe's Avatar
redred65cpe
For bolts, Stage 8 and a little anti-seize.
larry
Old May 28, 2009 | 01:46 PM
JohnZ's Avatar
JohnZ
larry
Correct! Before the Stage 8 locking bolts were available, I used ARP NASCAR small-hex pre-drilled header bolts and safety-wired them. If you don't use one of those two alternatives, header bolts will ALWAYS loosen up - they're too short to stretch and develop/maintain clamp load in the joint like stock manifold bolts do, then the gaskets fail.
Old May 28, 2009 | 01:57 PM
AZDoug's Avatar
AZDoug
C1 of Year Finalist (performance mods) 2019
2017 C1 of Year Finalist
I used the RemFlex gaskets and standard bolts.
No loosening so far.
I bought some Stage 8 bolts to use for when I thought the gaskets would blow out, but haven't had a chance to put them on,as the gaskets are still good and the bolts haven't loosened.
The only thing you gotta watch with the RemFlex gaskets is they are soft, it is easy to damage them if you try to force one into place, like you can force a hard std header gasket.
Doug
To Header question
