My '67 Vert Budget Rebuild
Not sure which side of town you're on....but there is an absolutely fantastic bunch of guys that are part of this group. Notice it's not a club...clubs have rules! Most are on the north side..spring cypress to 1488..but we have some out on Sugarland and Kema area too. They have tons of resources and all love to pitch in to help. Check them out!
http://www.nwhoustonvette-rods.com/
Thanks for the link. You may be getting a PM from me if we get if we get stuck on something.
Blake
Update
We got the engine out this weekend and started removing a bunch of other things from the engine bay. The engine casting number says that it is a 64-67 327 2 bolt. The engine stamp number is 6101643 F092IHE I am not sure what it means though; can anyone help here? It's pretty much clean, but we are going to clean it some more and then maybe start painting the engine bay next weekend.
I also had a question about the wiring harness; we are going to order an engine and head lamps harness from Letric Limited, I talked to their support and they said that it plugs in to the fuse box which is fine. I am wondering if the other wires that come out of the firewall near the wiper motor are includeded with the harness. Does anyone know? See the last pic for what I am talking about.
On to the pics.
Up and out...
Casting numbers
Other numbers
Tons o' parts
Me cleaning away
Our rig for staying out of the sun
Un-routing more wires
Both inner and outer heater/evaporator boxes out. What a pain in the @&*
Gunk engine cleaner and a power washer does worlds...
On to the pics.
Up and out...
Casting numbers
Other numbers
Tons o' parts
Me cleaning away
Blake, the wires I believe you are talking about which come out of the firewall close to the wiper motor are part of the instrument panel harness, and come out to the wiper motor, ballast resistor, etc. If you are not replacing that one also, just reuse it and plug everything back the way it came apart (assuming it was plugged up correctly and not butchered up. The Lectric Limited harnesses you are buying will plug right in and are routed righto to the places they plug into. You guys look like you are having fun. I gave my dad a 62 corvette for father's day a few years ago and we have a ball together! I have a video of when I gave it to him and if I can figure out how to put it on U-Tube I will post here someday. Keep up the great work! Jim
Thanks,
Blake
Thanks for the info.
Wow, all that from the stamp code. Can you tell me how you found that out? Is there a way to get the VIN number of that number car off the assembly line? I would like to try to find the car that the block goes into to potentially help the owner make it numbers matching.
Thanks,
Blake
Thanks,
Blake
If the engine is out of a coupe, the VIN will be 194376S101643 and it is out of a convertible it will be 194676S101643.
As for deciphering the numbers on the engine stamp pad (6101643 F092IHE):
6101643----6 is the model year and 1643 is the sequential VIN. The VIN numbers start at 100001 for all midyear Vettes.
F=Flint Engine Plant
092I=Sept.21
HE=300 HP w/manual trans
3858174 is the 327 block casting number used in 66 Vettes.
The NCRS has a tremendous collection of reference material for sale on their website www.ncrs.org. The information that I gave you came from the NCRS Pocket Spec Guide and Mike Antonick's "Corvette Black Book".
Also, check out these sites:
http://www.nastyz28.com/sbchevy/sblock.php
http://www.mortec.com/castnum.htm
http://www.teufert.net/sbchevy/sbchevy.htm
http://lbfun.com/Corvette/Tech/vettetech.html
Interesting note. I happen to have a Vette with the stamp pad exactly one year prior to yours.
We got a lot of cleaning, sanding, and grinding done this weekend. It was a lot of work, but I think it will pay off end.
Also, I dont know if you can really call this a budget rebuild anymore. I talked my Dad into the Vette Brakes performance plus suspension system. So, we will be ordering that kit and a new calipers and master cylinder kit from them in the next couple weeks.
In the third pic from the bottom, does any one know what the 294 stands for that is on the pass. side firewall?
Received 1,762 Likes
Ttt
Man looking good just take it slow and the job will tune out better. Dont worry about how long it takes you, it will be pay off in the end...
#34
If the front end is original to the car and the innerfenders have not been changed, that was a BB car.
#35
Thanks,
Blake
Thanks,
Blake
Thanks for the progress reports, I am enjoying following this thread...
Tim
#36
#37
Received 2,127 Likes
This is a great story, keep posting with details. Your work progression and scope of things is classic, "project creep". You'll love the results. Dennis
#39
This weekend we got all the suspension installed and a couple other odds and ends. We tried to install the battery tray, but we could not get it to fit. We would get the bolts in on one side of the frame, and then the holes on the other side were about a inch off. I think it got bent some how, so a new one is being sent to us.
We did some cutting on the lower bumper support bars to get them to fit with the Vette Brakes mono spring, but we did not get a chance to re-install them yet. I will get pics of that when we have them finished.
Next weekend we are going to tackle rebuilding the a/c and heater boxes. I am not looking forward to it, but hey, it has to be done.
Here are the pics.
Blake
Here are the pics.
Blake
